  • SN95 4.6L Mustang Tech
Hood Clearance For 351 In New Edge Stang (99-04)
  • Thread starter Thread starter Jabez5885
  • Start date Start date Jul 6, 2012
J
Jabez5885
  • Jul 6, 2012
Gonna do a 351 push rod in a v6 stang with the FAST engine management system. Seems to be the lowest clearance, but I hear the issue is with the distributer. Gonna try using the Mach 1 hood. Anyone have any advice?
3,287
24
69
Broke
Jul 7, 2012
  • Jul 7, 2012
Starting with a V6 is a huge mistake. Mach 1 hood has a hole for the shaker system...? Cobra R gives more clearance. A typical cowl hood would give most clearance.
mransr
1,188
36
98
Riverside, SoCal
Jul 7, 2012
  • Jul 7, 2012
ya, I don't think a Mach 1 hood will help much if any, and you would probably have to mount the shaker solidly to the hood rather than the engine...I'd suggest a cowl hood too...
J
Jabez5885
  • Jul 7, 2012
Starting with a v6 is bad? Because? I'm also using a 94/95 as a donor, but I'm using the v6 4r70w. A v8 doesn't give much help other then a more solid rear end. what's the advantage and disadvantage between gt and regular v6? Also.....I already know that a cobra r and cowl hood would work, but I personally think they are horrible looking IMO.
3,287
24
69
Broke
Jul 7, 2012
  • Jul 7, 2012
V6 vs V8. Yes rear end. Yes brakes. etc.
Kornnut
1,999
48
108
Tulsa
Jul 8, 2012
  • Jul 8, 2012
What intake are you going with? If you're going with an elbow style you may have to run a cowl. Also I would start with a v6 as well. Cheap, 4r, and non hydroboost(I think). 6 bolts and the rear is out, and not many more to swap the brakes.
D
Deleted member 38176
Jul 8, 2012
  • Jul 8, 2012
Reactions: 4inastang
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 8, 2012
  • Jul 8, 2012
So what Kmember are you going to use ? The stock one from the donor or an aftermarket ? I think MM makes a Windsor motor swap K that lowers the motor for extra clearance.
I think starting with a v6 car to swap into is actually smart. It makes your original purchase price CHEAP and the chassis wont be beat up from being run hard. If you are upgrading the brakes anyway its no big deal and maybe you want to put a 9" or an IRS in anyways so who cares ?
There were early SN95s that hda 351w motors in them and I don't know if they had a special hood. Check out the Saleen S351 and see what hood it used. Obviously its not the same body style but if it used a stock hood there is no reason the standard hood shouldn't fit in the later SN95.
J
Jabez5885
  • Jul 15, 2012
Thanks for advice. The intake faces straight up, so that's why I wanted to use the Mach hood. The elbow intake will def need a cowl hood. With the 94/95 donor car I was just gonna switch everything over w/ aftermarket kmember of course.
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
2000ElectricGreen
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
9
1995 Mustang GT Crank no Start
  • 95gtV
  • Sep 1, 2023
  • 1994 - 1995 Specific Tech
3K
1994 - 1995 Specific Tech Dec 4, 2023
SRago
