Hood Hinge Help
  • Thread starter Thread starter Cdaniel
  • Start date Start date Mar 9, 2004
Cdaniel
220
Arizona
Mar 9, 2004
  • Mar 9, 2004
So what's up with these flimsy Mustang hood hingies. Are they supposed to bend with the spring pressure?
I need the inside scoop on how to get my hood aligned properly. New hinges, there is resistance keeping the back of the hood from coming down smoothly. It wants to skew to the passenger side. How much gap should there be between the cowl and the hood.
Help!
Cliff Daniel
Tempe, AZ
66 Fastback
http://members.cox.net/cwdaniel/stang page/indexstang.htm
hungrymonkey
White by Birth, Trash By Choice
12
108
Oregon.
Mar 9, 2004
  • Mar 9, 2004
mine bent last year. turns out that one of the Nuts that were welded to the engine bay had come loose.
the only advice I have about the hood is to tighten the bolts just enough so it will not slide around. but loose enough to still be slid around with force.
then close the hood and push it until the cowl area lines up, and the sides do as well.
then slowly open the hood without messing up the alignement and tighten the bolts.
there is probably a better way of doing it. but that pretty much worked for me.
19sixtynine
9
Boise, ID
Mar 9, 2004
  • Mar 9, 2004
Yea, what he said, but take out the hood latch as well... that way you don't have to mess with it "miss-aligning" when your trying to line up the gaps. When you get your hood where you want it, install the hood latch.
Finer Points Of Aligning Front Sheet Metal?
  • Cool Beans
  • Apr 26, 2015
7K
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2015
Cool Beans
Need Help, Car Wont Start, I've Gone Through Both Checklists
  • 93silverlx50
  • Jul 22, 2017
  • 2 3
13K
Fox 5.0 Mustang Tech Apr 30, 2019
General karthief
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
Controlling Under Hood Temperature?
  • horseballz
  • Jun 2, 2013
6K
Classic Mustang Specific Tech Jun 18, 2013
65ShelbyClone
Fitting A 67 Shelby Nose Section.
  • horse sence
  • Mar 21, 2014
2K
Classic Mustang Specific Tech Mar 21, 2014
horse sence
