  • SVT Tech Forum
Hood Vents
  • Thread starter Thread starter jdblown03
  • Start date Start date Jun 9, 2004
jdblown03
18
  • Jun 9, 2004
Whould ther be any benefit at all to removing hood insulation and pulling out back of vents to get more air in? Or the direction of the airflow would'nt help?Also fixing to do first oil change and I keep hearing not to go synthetic on 1st oil change. Any advice on either would be helpful.
T
Trumps01Cobra
14
Alabama
Jun 9, 2004
  • Jun 9, 2004
I heard the same thing.
Lawman85
126
  • Jun 9, 2004
I read the same about the synthetic. I believe the article said that the synthetic would prevent everything from breaking in and seating correctly. They recommended starting synthetic around the 6000 to 10000 mile mark. I hope I'm getting that right. It was an article from Automobile Mag. or Car and Driver... can't remember, few years ago.
T
travis0712
233
Missouri
Jun 9, 2004
  • Jun 9, 2004
I removed my vent backing... you can really feel the heat come out of the car with them out... pics are in my sig....
PDubs
1,138
Always farging hot in Texas
Jun 9, 2004
  • Jun 9, 2004
Removing the hood liner from underneath the hood vents will greatly assist in releasing the excess heat. Also, you should wait until at least 5k before changing to full synthetic.
jdblown03
18
  • Jun 10, 2004
Thanks, will probably do in the morning. Do you think there is any hp gain?
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Jun 10, 2004
  • Jun 10, 2004
Your cars engine is "seated" within the first 500 miles. Switch to a full syn anytime after that. Here is a GREAT POST from the SVTPerformance.com forums by a Cobra owner who is also a Tribologist (Oil Expert). He knows his stuff when it comes to oils!
http://www.svtperformance.com/forums/showthread.php?s=&threadid=14856
http://www.svtperformance.com/forums/showthread.php?s=&threadid=79898
As for removing your hood insulation... not much gained there. You might not like the results... most terminators are NOT PAINTED on the bottom side of the hood. I do suggest you perform the "Postban" hood mod. This mod opens up the vents in the hood extractors to allow for more heat to escape.
None of the aforementioned mods will increase HP.
U.M.
P.S. For all of you posting about engine break-in before going to synthetics... what about those cars (Z06) that come with a synthetic oil fill from the factory? I wonder how their engines EVER break in correctly....
R
Rice Eatr
10
Michigan
Jun 10, 2004
  • Jun 10, 2004
If you take the blanket off you'll see that Ford didn't paint the entire underside of the hood. I have also heard of people having their paint discolor around the vent opening due to the additional heat being released.
jdblown03
18
  • Jun 12, 2004
Thanks for advice on oil, "postban", do you meaan just cut out small back section of plastic?
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Jun 12, 2004
#10
  • Jun 12, 2004
  • #10
You can cut the plastic rain flaps off completely and remove them if you want. You can cut just the tabs on the front side of the rain flaps and then fold them back up and under the hood blanket. Do a search for "Postban Hood Mod" over on SVTPerformance.com.
U.M.
T
travis0712
233
Missouri
Jun 12, 2004
#11
  • Jun 12, 2004
  • #11
My hood blanket has been off for a few weeks now, even after a trip to alabama and chicago.... lots of street cruizing... no mess, no cracks in the paint, no signs of anything negative... I can't say how much it helps.. but it has to cool things down at least a little bit - makes me feel better anyhow and thats what counts
My hood is painted too... maybe because it is a white care, nonetheless, it is finished in white :dunno:
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
  • SVT Tech Forum
