Hooking Up E-brake After 5 Lug Conversion
ARE THE two rear cables stock on a late model or do have to purchase from latemodel?
I purchased all mine new from LateModelResto.
Note: They do not come with the hardware. You will need to buy a couple of nuts for the center cable as well as the crescent rings for attaching the cables to the rear calipers. You can get those at a local parts store.
No. They are purely Ford Racing aftermarket cables. They came stock on no vehicle.
You can use Sn95 cables, but they require you cutting the mounting bracket from a donor car and tack welding it into your trans tunnel
