  • 2005 - 2009 Specific Tech
Hooking up my radar detector
  • Thread starter Thread starter stang8urimport
  • Start date Start date Sep 2, 2007
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Sep 2, 2007
  • Sep 2, 2007
I had mine hooked up in the black 07 GT, but the Grabber Orange car has active theft and there is more stuff in the over head light thing... and I hooked it up the exact same way, the gray wire and black wires, and they stayed on all the time and shut off after like 10 minutes of having the car off in my Black GT, but this one, once I turn the car on and shut the door, the radar detector turns off. wtf is up with that? Any ideas???
Nick
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Sep 3, 2007
  • Sep 3, 2007
probably hooked into the motion sensors....
D
dawater
  • Sep 3, 2007
Mine's like your's and I did the same thing--wired it up wrong at first. I ended up hooking into almost every wire up there. I finally got it to work with the doors shut. I don't think any of them will turn off automatically on my car. I'm going to run a switched 12V wire to the fuse box when I get a chance. I'd love to know if someone has an answer to this. Right now, I'm just manually turning the thing off and on. Can't remember which wires I ended up with.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Sep 3, 2007
  • Sep 3, 2007
Yeah, I have no idea. I wish it would just hook up the same way. I'd really not like to have to run a wire down the a pillar and crap. Hopefully someone else will know
R
rx9790
  • Sep 11, 2007
I just ran mine to the middle black wire and I beleive a green wire. Oddly the black is a constant +12v. A meter is your friend and you should never have had to try all the wires. I do have to manually turn off but I noticed that wire loses power after so long because when I went out the next morning it ran a self test when I opened the doors then stayed on all day.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Sep 11, 2007
  • Sep 11, 2007
Yeah, I ended up using the black wire and just grounding my detector wire to the chassis. Works perfect.
G
GT Dave
34
Cincinnati, Ohio
Oct 11, 2007
  • Oct 11, 2007
Bringing this thread back from the dead.. PoopDaw has this worked out for you and where did you ground to the chassis exactly?
Thanks!
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Oct 12, 2007
  • Oct 12, 2007
Under the overhead light panel, I just drilled a small hole into the metal (obviously NOT the roof) and used a self tapping screw and an eyelet connector. It's worked perfectly every since. Turns itself off after 15-20 minutes.
blackraven
Trenton, NJ
Oct 12, 2007
  • Oct 12, 2007
I'm curious what type detector you're running & (I'm assuming so) is it mounted above/below the overhead light console? Any pics?
stanmckinney
1,188
Oct 12, 2007
#10
  • Oct 12, 2007
  • #10
I'd like to see pics too.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Oct 13, 2007
#11
  • Oct 13, 2007
  • #11
I'm using a Passport 8500 right now. I don't have any pics, but I'll try to get some soon.
Nick
blackraven
Trenton, NJ
Oct 13, 2007
#12
  • Oct 13, 2007
  • #12
Nick
I'm using the same, so I'm always interested in how others have theirs mounted. Right now, I'm using the included mount & have it just over my NJ inspection sticker (lower drivers side). I originally placed it above the overhead lights but the texture of the pony kept it from sticking there.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
W
Interior and Upholstery New Member auto dimming mirror install issue
  • WigSnatcher92
  • Aug 25, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2025
Mustang5L5
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
