Horn gives weak, short noise?
  • Thread starter Thread starter 66 Restomod
  • Start date Start date Jul 11, 2009
66 Restomod
203
Raleigh, NC
Jul 11, 2009
  • Jul 11, 2009
Just wondering if anyone has had this issue. I recently noticed that the horn on my 66 gives a weak, very short sound when I push the horn button. It doesn't last more than a second and it's barely audible. I checked the manual and the horn seems to run through the headlight switch? Interestingly the passenger side brake light and taillight also is very dim but otherwise functions. I see that those lights too seem to run through the headlight switch. My switch is only a year old. Everything else in these systems is basically new (wiring, lamps, etc.). What could cause this weak horn? And is the headlight switch suspect? Thanks.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jul 11, 2009
  • Jul 11, 2009
The horn runs through the turn signal switch. Check all the connections between the steering wheel and horns to be clean with good contact. With the engine running, try again. Horns are also tuneable, for loudest tone. The screw on the back will adjust them. Don't just twist away at it, keep track so you can get back where you started if you need to.
66 Restomod
203
Raleigh, NC
Jul 12, 2009
  • Jul 12, 2009
Thanks this helped. I put a wire to each horn right from the battery and the horns themselves definitely work and the tune seems ok to me. So, must be the wiring. I have the steering wheel off now and am going through the turn signal switch but it's fairly new and nothing is obviously wrong with it. I cleaned up some of the grease from where the horn contacts slide around the copper strip on my LeCarra wheel hub. But it all really looks functional. I'm thinking the weak horns and the weak passenger taillight have to be related. I saved $60 by not needing new horns, maybe I need to spend $80 on a new turn signal switch even though the current one appears good.
yeloxr7
429
  • Jul 14, 2009
The horn in my Cougar was weak and inconsistent. I added a relay to the circuit that directs full battery current to the horns. Now they work every time and are sufficiently loud.
sportsroof69
231
Huntsville, AL
Jul 17, 2009
  • Jul 17, 2009
If you don't mind an aftermarket horn, try some Hella's. My Buell had a single Hella that would scare drivers with their windows rolled up. I liked it.
66 Restomod
203
Raleigh, NC
Jul 18, 2009
  • Jul 18, 2009
Thanks, fixed!
I was replacing the turn signal switch the other day and when I removed the steering wheel (it's an aftermarket LeCarra with hub) I noticed that the retaining nut was tight enough to keep the wheel from falling off -- but probably not tight enough for the horn contacts to make good enough contact. So when I reassembled everything, I made sure the steering wheel retaining nut was nice and tight. So the horns work well now. But I will also grind around the horn assembly mounting bolts on the radiator support to make sure they have a good ground too. (Of course there's a fresh turn signal switch in there now, but I really think the fix was actually the loose nut...)
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
K
Electrical Weird horn - headlight issue
  • Kuwait-Foxbody
  • May 27, 2024
Fox 5.0 Mustang Tech May 28, 2024
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
  • dan50
  • Jul 18, 2026
dan50
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
