Horse Power Estimate?
Jan 3, 2011
29
How much horse power do you think I will make using my stock 5.0 short block adding Trick flow 170cc heads,stage 1 cam, Roller Rockers, Mac equal length headers,Explorer GT40 intake with 75mm MAF,75mm Throttle body, 24lb injectors,cold air intake. Also it has off road H-pipe and flows.3.73 gears, with a T-5. Just wondering what you all might think it will make. New to the whole injection thing. Thanks for your time.
Thanks hope to have it at the dyno next weekend. Just wanted to have something to look forward to.just to have fun over the summer.Will be adding a main girdle and a 76mm with .96 a/r over the winter. Thanks Guys
I'm very curious to see what you put down for numbers! my set up is similar, but my 170 cc heads are ported polished and shaved so my compression is 10.75:1 and I have an Edelbrock performer intake. The rest is pretty much the same. It goes like hell but all i got to compare it to is from when it was a 2.3l
