Hot intake
wotpoc
I have a Kenne Bell SC on my 88 GT with AFR heads. I'm thinking of pulling the intake and blocking off the ports in the head used for EGR using Felpro 1250 gasket kit which comes with the block off plates. The intake gets so hot I can't touch it and I think blocking off those ports will allow it to run much cooler and get more power. Does this make sense? :shrug: What are drawbacks?
Removing the egr without disabling the function within the computer can lead to part throttle detonation, and lower fuel economy.
The higher temps of the intake are not a problem, until the air charge is allowing detonation.
The egr removal question has been hashed over pretty well here. A quick search should give you a good idea of the potential consequences.
I have a summary written here...
http://www.freewebs.com/vristang/faqs.htm
... toward the bottom of the page.
jason
