Hot start trouble
00 Red SS
270
Grain Valley, MO
My car fires right up when its cold but after a drive or idling awhile it will just crank untill either the battery goes dead or i might get lucky and it will crank untill i get it to spit and sputter for a second before it completly fires all 8 cyl.. What causes this? The car has no trouble cranking just doesnt want to fire and start.
Chase thses rabbits and if you don't find anything, repost. :bang:
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) TFI module
C.) PIP sensor in distributor
D.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
E.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
F.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
G.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
If it starts then, you have a fuel management issue. Continue the checklist with emphasis of fuel related items that follow. If it doesn’t ,then it is a computer or timing issue: see Step 4.
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off only likely if the engine has been worked on recently).
I think its gotta be narrowed down to this since it fires just fine cold.
A) how do you check the iab? I just put a different one on and looked it over the plunger moved and it didnt have any carbon buildup, if you unplug it at idle itll drop a couple hundred rpm's. Im also chasing something that keeps killin my car everytime it revs.
B) Car runs cold so i doubt it.
C) The car runs fine, i initally had the timing advancd too much and the starter would barely crank but now the starter spins like it should. Could it be too retarded but then it wouldnt fire when cold would it?
D) Cars fires cold so firing order is good.
When it cranks i sometimes get a sputter but have to give it throttle to get the rest of the cylinders to fire, does that mean my timing is getting way off when the car warms up?
Combine this hot start problem with my car dying, instead of returning to idle speed it just drops all the way down till it dies, everytime from clutching while driving or just revving and i am very frustrated. It wants to die and not start what a great combination, but strange because it fires fine cold and will idle just fine if you play and gently ease down the rpms' :bang:
