Hot stuff...
The garage looks really good. :nice: At first I thought it was going to be a pass-through on the left bay, which is something I always thought was cool. I can see spending many hours out there. Nice job :banana:
What occurs in theory and reality are two different animals. If tweaking the TPS feels like it helped, it probably helped. Twenty-something year old cars, aging components and a mix of OEM and aftermarket components are all contributing factors why something might not work as well is it should (in theory) or like it did when stock.
I think your problem is local to the 2 cylinders that cooked the wires.
Think about it logically.
They are likely running lean.
What causes a cylinder to run lean, but another to run fine?
Fuel injector on that cylinder(s).
Other than a vacuum leak, that is the first place I would have looked before replacing parts that affect every cylinder.
Thanks guys. You know, after over a year, and finally thinking its fixed, I cant take it for a ride because of the snow storm (CT)...but i'm not complaining....we lucked out in my town and avoided hurricane sandy...really lucked out.
I will keep that in mind 411....to look for issues related to individual cylinders. I think I have the old wire set, which were numbered....and actually I have the old plugs so I check them at some point. I'll post again after I take it for a ride. Thanks.
Well, thought it was fixed, Hissin you were right about it not being the TPS. Seemed that first ride after I adjusted the TPS was a tease. I am 'afraid' to take it out on the road as it will stall after idleing for 10 minutes. Luckily its not my DD. Swapped a new distributor/TFI I had bought a while back, and also put in new o2's,,,and it still will stall at idle. Just got a fuel pressure gauge and am learning how to use it. Just re-read this thread for hints...I went from bucking which I'm pretty sure was fixed by a new coil, to missing/bogging under load which I thought was fixed by a TPS adjustment and now have stalling after it has been at idle sitting in the driveway. For all I know I'm still chasing the same original problem. Hopefully the FP guage helps me out.
Code 14 - Ignition pickup (PIP) was erratic – the hall effect sensor in the distributor is failing. Bad sensor, bad wiring, dirty contacts.
Revised 10-Dec-2012 to add PIP diagnostic testing & Wells info
The PIP is a Hall Effect magnetic sensor that triggers the TFI and injectors. There is a shutter wheel alternately covers and uncovers a fixed magnet as it rotates. The change in the magnetic field triggers the sensor. They are often heat sensitive, increasing the failure rate as the temperature increases.
PIP Sensor functionality, testing and replacement:
The PIP is a Hall Effect magnetic sensor that triggers the TFI and injectors. There is a shutter wheel alternately covers and uncovers a fixed magnet as it rotates. The change in the magnetic field triggers the sensor. A failing PIP sensor will often set code 14 in the computer. They are often heat sensitive, increasing the failure rate as the temperature increases.
Some simple checks to do before replacing the PIP sensor or distributor:
You will need a Multimeter or DVM with good batteries: test or replace them before you get started.. You may also need some extra 16-18 gauge wire to extend the length of the meter’s test leads.
Visual check first: look for chaffed or damaged wiring and loose connector pins in the TFI harness connector.
Check the IDM wiring – dark green/yellow wire from the TFI module to pin 4 on the computer. There is a 22K Ohm resistor in the wiring between the TFI and the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 22,000 ohms +/- 10%.
Check the PIP wiring - dark blue from the TFI module to pin 56 on the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 0.2-1.5 ohms.
Check the SPOUT wiring – yellow/lt green from the TFI module to pin 36 on the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 0.2-1.5 ohms.
Check the black/orange wire from the TFI module to pin 16 on the computer. Use an ohmmeter to measure the wire resistance from the TFI to the computer. You should see 0.2-1.5 ohms.
Check the red/green wire; it should have a steady 12-13 volts with the ignition switch on and the engine not running.
Check the red/blue wire; it should have a steady 12-13 volts with the ignition switch in Start and the engine not running. Watch out for the fan blades when you do this test, since the engine will be cranking.
If you do not find any chaffed or broken wires, high resistance connections or loose pins in the wiring harness, replace the PIP sensor or the distributor.
The PIP sensor is mounted in the bottom of the distributor under the shutter wheel. In stock Ford distributors, you have to press the gear off the distributor shaft to get access to it to replace it. Most guys just end up replacing the distributor with a reman unit for about $75 exchange
It is not uncommon to get a defective PIP sensor in a remanufactured distributor.
PIP problems & diagnostic info
Spark with the SPOUT out, but not with the SPOUT in suggests a PIP problem. The PIP signal level needs to be above 6.5 volts to trigger the computer, but only needs to be 5.75 volts to trigger the TFI module. Hence with a weak PIP signal, you could get spark but no injector pulse. You will need an oscilloscope or graphing DVM to measure the output voltage since it is not a straight DC voltage.
See http://www.wellsmfgcorp.com/pdf/counterp_v8_i2_2004.pdf and http://www.wellsmfgcorp.com/pdf/counterp_v8_i3_2004.pdf for verification of this little detail from Wells, a manufacturer of TFI modules and ignition system products.
Code 18 - SPOUT out or wiring fault - look for short to ground in SPOUT wiring going
back to the computer. Possible bad TFI or defective 22 K resistor in the IDM wiring
This code can disable spark advance and reduce power and fuel economy.
Remove the passenger side kick panel and disconnect the computer connector.
There is a 10 MM bolt that holds it in place.
Disconnect the TFI module connector from the TFI and the measure the resistance between the yellow/lt green wire and ground.
You should see greater than 100 K (100000) ohms.
Check the resistance from Pin 4 on the computer connector (dark green/yellow) and the dark green/yellow wire on the TFI connector. You should see 20-24 K Ohms (20,000-24,0000 ohms). The resistor is located in the wiring harness about 6” from the connector. You will need solder and heat shrink to replace the resistor if it is bad.
Next measure the resistance between the yellow/lt green wire on the TFI module connector and
Pin 36 on the computer connector. With the SPOUT plug in place, you should see less than 2 ohms.
The following is a view from the computer side of the computer connector.
This diagram is the wire side of the computer connector.
a9x-series-computer-connector-wire-side-view-gif.71316
Putting the distributor back in and setting the timing.
You can forget about anything beyond this point if you don't have access to a timing light. You will never get the timing set right without one.
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole, crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer on the engine block.
The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor to about 11:00, since it will turn clockwise as it slides into place.
Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block, (you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing.
If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor, but don't tighten it too much, as you will have to move the distributor to set the timing. Note that there is no such thing as one tooth off on a 5.0 Mustang. If it doesn't align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
Setting the timing:
Paint the mark on the harmonic balancer with paint -choose 10 degrees BTC or 14 degrees BTC or something else if you have NO2 or other power adder. I try to paint TDC red, 10 degrees BTC white and 14 degrees BTC blue.
10 degrees BTC is towards the drivers side marks.
Note: setting the timing beyond the 10 degree mark will give you a little more low speed acceleration. BUT you will need to run 93 octane to avoid pinging and engine damage. Pinging is very hard to hear at full throttle, so it could be present and you would not hear it.
Simplified diagram of what it looks like. Not all the marks are shown for ease of viewing.
ATC ' ' ' ' ' ' ' ' ' '!' ' ' ' ' ' ' ' ' ' BTC
---------------- > Direction of Rotation as viewed standing in front of the engine.
The ' is 2 degrees.
The ! is TDC
The ' is 10 degrees BTC
Set the timing 5 marks BTC. Or if you prefer, 5 marks towards the driver's side to get 10 degrees.
To get 14 degrees, set it 7 marks BTC. Or if you prefer, 7 marks towards the driver's side to get 14 degrees.
The paint marks you make are your friends if you do it correctly. They are much easier to see that the marks machined into the harmonic balancer hub.
At this point hook up all the wires, get out the timing light. Connect timing light up to battery & #1 spark plug. Then start the engine.
Remove the SPOUT connector (do a search if you want a picture of the SPOUT connector) It is the 2 pin rectangular plug on the distributor wiring harness. Only the EFI Mustang engines have a SPOUT. If yours is not EFI, check for a SPOUT: if you don’t find one, skip any instructions regarding the SPOUT
Warning: there are only two places the SPOUT should be when you time the engine. The first place is in your pocket while you are setting the timing and the second is back in the harness when you finish. The little bugger is too easy to lose and too hard to find a replacement.
Start engine, loosen distributor hold down with a 1/2" universal socket. Shine the timing light on the marks and turn the distributor until the mark lines up with the edge of the timing pointer. Tighten down the distributor hold down bolt, Replace the SPOUT connector and you are done.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
attachment.php
thnks Jrichker, i'll have to check codes again. I thought I checked codes after i swapped the dizzy and tfi and came up w/ 11's. Checked FP today and it's low at 30 w/ the vac line at the FPR disconnected and plugged. I will check the fuel pressure again as I used a cheap guage and don't trust it. When I disconnected the gauge after the readings were done, I looked at the fittings and one of the 'needles' was a little bent. I poked at it a little and it simple fell out. Hooked it up again and its not working so....I will return it and try again to verify.
If the pressure it is at 30, that is too low right? Would that be low enough to cause stalling etc. correct?
30 is definitely low, but the car will run down the road with that.
What I have seen is failing fuel pumps will drop off pressure gradually sometimes.
Each time I have seen that, I have focused on the regulator, but each time it was the fuel pump.
It dropped PSI gradually, slowly at first, then it degraded and dropped PSI quicker and quicker as it got lower.
Hopefully your gauge was wrong and this is not the issue.
Can't believe it. Returned the FP gauge, now reading 30 just by running the pump, and w/ motor running 43 w/ Fuel Pressure Regulator Vac line blocked/disconnected and 35 connected. First gauge was fubar'd or I'm getting inconsistant readings? I was actually hoping it was the pump ratio411!! Pressure was steady while running then finally stalled after 10 to 15 minutes at idle. Gauge kept pressure for a while after the motor was off. Checked codes, didn't think i had any but got 14 again and 95. So PIP and Fuel Pump Circuit Failure? So, 14 cand be PIP(distributor), TFI or resistors as jrichker or TFI?, but is the 95 telling me I have a ground problem in the fuel system? Thanks folks i appreciate everyone's help so far.
Code 95 Key On, Engine not Running - the following test path is for 86-90 model Mustangs.
The 95 code is because at one time or another, the fuel pump relay hiccupped and didn't provide power the pump when the computer told it to run. Sometimes this is a one time thing, other times it is a no run or runs poorly condition.
fuel-pump-wiring-89-90-5-0-mustang-jpg.55493
Using the diagram, check the red/black wire from the fuel pump relay: you should see 12 volts or so. If not, check the inertia switch: on a hatch it is on the driver’s side by the taillight. Look for a black rubber plug that pops out: if you don't find it, then loosen up the plastic trim. Check for voltage on both sides of the switch. If there is voltage on both sides, then check the Pink/black wire on the fuel pump relay: it is the power feed to the fuel pump. No voltage there, check the Orange/Lt blue wire, it is the power feed to the fuel pump relay & has a fuse link in it. If there is good voltage there & at the Pink/black wire, swap the relay.
Some Mass Air conversions neglect to run the extra fuel pump wire, and they always have a 95 code. See http://www.stangnet.com/tech/maf/massairconversion.html for more information on the Mass Air wiring conversion.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
About to give up and i think I've reached my limited skills in trying to trace this issue. In trying to resolve code 14 I changed the dizzy and TFI again. Stalled twice and still misses. How the heck do you guys do it? I mean, seems simple, fuel and spark, its just that there are like 20 different things that produce the same poor running conditions.... the codes only point you in a direction..... and parts and tools even new are faulty and I'm not going just by my experiences but by the hundreds of similar posts out there. Okay had to vent...here's where I'm at.
Fuel pressure is at 43psi, new dizzy, tfi, O2, fairly new are the coil, plugs, wires, ran seafoam green, Tps at 97 or so, cleaned MAF and IAC, last codes are 14 Koeo and none for Koer. After warm up idles slightly rough and stalls once in a while, exhaust has always smelled 'rich', runs better than before last dizzy and tfi change.
Oh, this killed me yesterday when I replaced the dizzy and TFI. I was checking the old one for the "grease/paste" that is inbetween the tfi and the mount....and when I pulled it apart I saw one of the 3 tfi prongs was bent....don't think it was even inserted in the slot, it was bent at least 45 degrees. I was like great! this is it!....I went inside to show the girlfriend as the car was at idle with the new dizzy and tfi...and just as I was showing her the bent prong/tab ,,,,the car stalls!!!!!!! Took it for a ride after disconnecting the battery for a while, just incase it was a 'memory' thing, and it did not hesitate as much, just a slight stumbling and 2 stalls as I said.
So, either
a)some of the things I'v done have solved issues but then other issues popped up,
b)still chasing original stalling, hesitating problem, or
c)should give it to a pro....anyone in CT? (three shops including a dealership have looked at it, two of them changed the coil, the dealership found nothing)
i'd appreciate any additional thoughts. It hasn't thrown the 95 code lately so I'm hesitant to devote time to jrichkers post on fuel issues. It has stalled again and didn't throw out 95. Couple of more things...the car does have a jabocs ignition and previously the plugs were at 0.06...I bumped them down in the past to 0.05 w/ no help. What else....timing at 12 and HOLY CRAP....almost forgot...the balancer is wobbleing a little, at least 1/16 to 3/16" I feel it above 3000 rpm or so. Could that cause stalling, hesitation? (it is on the to do list) Have asked the shops to check grounds but haven't myself. And the last question....I've read about dizzy's being off 180 degrees, could that cause the issues, I have had it off/changed several times and it is possible. Lots of questions and hope for some insight. Thanks.
Chase the problems one at a time. Clear the codes and dump them again. If you still get a code 14, you still have PIP or wiring problems. Fix that first. Revisit my post on above on PIP problems and go through the wiring checks.
Well, I was planning on going through your post jrichker and check the TFI to computer connections.... went to move the mustang in the garage to fit another car in, and heard a rattle from underneath. Seemed like it was one of those tubes that run to the mid exhaust pipe, sounded just like it when I shook it. The tube seemed like it came loose or something. Checked the ends to make sure they were attached and put a zip tie on it to secure it. Had the girlfriend rev the car a little while I listened underneath, and man, there is a rattle and I think it's coming from the oil pan. Saturday I'll put it up on jacks and try to really locate the sound, for all I know I dropped something into the headers or something, but it does not sound good.
So lucky....The rattle wasn't coming from the oil pan. I got underneath it yesterday and used a skrewdriver up against my ear to check and the rattle is coming from one of the cats. I do have a catless h-pipe and will swap. I guess if there is something in there that was blocking it may cause the hesitation...Hopefully doing the swap will fix it.
Do these cars have a KOER Continuous Monitor Diagnostic Test mode, aka "wiggle test" mode? I never tried it when I still had an EEC-IV Mustang.
Yes.
Turn the ignition switch to Run and listen for all the actuators and relays to click and cycle. Then you can wiggle each suspect connection or wire. Any connection that generates 2 or more faults stores the code results in the KAM. Then you can dump the codes and read the results.
Still working on this. Couple of things happened. Replaced the cat pipe with a Walker 2 1/4" w/ cats since the old one was making noise. (there's a whole story there but i'll spare you) Went to swap the tfi module with an old one I have, just for the heck of it, and one of the skrews on the dizzy is stripped. I thought great, perfect excuse to return the dizzy and get another under warranty. Well, swapped out the dizzy/tfi. Then tested the tfi harness for voltage and ohms to the ecu pins as per Jrichers code 14 post, which was good. And lo and behold....she stalled again after warmup.
So, after researching a lot, and getting a test light, remote start button and spark tester I tried to test a couple of things. I let it idle today and sure enough stalled after warmup. Then tested the input to the coil and got 12v on one wire. The other wire, which i believe is supposed to be a pulsed signal from the PIP, made the test light blink, both wires tested while cranking. So, seemed like input to coil was okay, but did not produce a spark. Replaced the coil. First startup, stalled after warmup. Yep. Of course it stalled again. 10 minutes later thought to check fuel pressure again, and seems good. But this time didn't stall. I mean it idled for like 25 minutes! There has to be a gremlin in there, it stalled the first time after the new coil but not the 2nd time? The last 20 times it has idled, then stalled. It is just messing with my head I tell you. Didn't want to take it for a ride as I don't trust it yet. Maybe tomorrow during the day if it doesn't stall. If it does stall I guess it's back to the checklist. Any thoughts folks?
I cannot gaurantee that this is your total problem, however, I can't believe no one has pressed you on this issue yet.
They must have missed it buried in your post.
You have no baseline timing whatsoever if your balancer has slipped at all, and moved the timing marks.
I would at least confirm that the TDC mark on the balancer is truely at TDC before proceeding.
If you can't be sure of the timing on your car, you can't be sure of anything else at all until that is either fixed or proven a non-issue.
I would go ahead and put it to the top of your list if you can, because a slipped balancer that has only slipped a tiny bit (like it sounds your's has), can only go on to become a balancer that has slipped a great deal. Been there, done that... It is a serious mechanical failure, not a gremlin in the wiring or someting.
Since we are discussing baseline timing, did you time the car with the SPOUT removed?
Did you put the SPOUT back snug?
Have you triple checked the firing order vs the placement of the plug wires?
Did you clean the balancer with a wire brush and/or sandpaper to make sure you are using the timing marks that you think you are using?
*I had this issue just yesterday. Squinting at the balancer while the timing light flashed, trying to distinguish between diminished/blurry markings. I like to clean the balancer, then put a thin line of White Out on top of the TDC mark. If you don't have an advance capable timing light, then put your mark on the degree mark you want your timing set at. Don't do both, unless you mark them distinctly different, because it's hard to tell which is which with the car running. If I do it with more than one mark, I will mark the TDC with a full line across thewidth of the balancer, then only place a dot or very short mark at the other timing location I want to see.
Do a quick search, Ford had a plug wire routing problem with the HO firing order. There are a pair, or 2 pair of plug wires that are right next to each other, that Ford specified that you seperate to prevent intermittent crossfiring. In other words, if you route your plug wires from distributor to the plugs in the order in which the wires naturally fall, like you would any other engine, then you will end up with crossfire sooner or later. The deliberate routing of these specific wires with other wires placed between them is called for by Ford, and probably a good idea. I haven't seen many misses fixed with this method, but I have seen it once or twice, so there is something to it. Sorry I don't recall the cylinders that need their wires isolated from each other, but it should be easy info to find. If it works for you, great, if not, it didn't cost you anything to do.
Yep 411, forgot to mention that, I did confirm it. Froze my but out there doing that. I guess the balancer is wobbling but hasn't slipped. And also did check the timing w/ the spout removed and just checked the spark plug wires for order like you said.
checked the ground wire for the computer
Right JKA. I think grounds may be next on the list, but I am reaching the limit of what I can do. I haven't really suspected gounds yet as the stall is consistant, and would imagine a ground issue would be more random, right? But I have been noticing something. Like I said the stall happens after it warms up, but it's almost always within a minute of the electric fan kicking on. I checked voltage at the alt after it kicks on and its within a tenth or so, but don't know if that 'checks' anything. I didn't install the fan, and wasn't an issue in the past, but I will check that wiring at least...well as best I can.
Take both battery cables off and remove the battery and check the fusible links at the starter relay and check for cracked or broken wires. Also take a good look at the ground behind the battery clean/tighten that. I have seen mustangs surge and stall ..my own mustang too because of loose or bad ground wires/or broke wires. Bad grounds and fusible links will make the computer throw all kinds of codes and will make your car stall.
