Fox Hot Weather Kills Motor
Fuel or fuel pump was my first thought but the next day i filled up and it done it again. All roads seem to lead to the TFI.
If i pull the codes, will it tell me if the TFI is bad? Can i take my TFI off and get Advance or Oreilly's to check it?
You would have a code indicating a bad PIP or TFI. same with a failing fuel pump.
I've had pumps that worked great until they got hot and then would just quit. tfi has the same symptoms. Works cold and dies at operating temp. Pull codes.
