How are the trickflow cams?
For an off the shelf cam, the trick flows are pretty good. The stage 1 has a good lope but it is very streetable. Yes the three Ford cams are stage 1, 2 and 3. You will probalby need an intake and heads before you can take advantage of it... otherwise you will probalby loose power.
Kevin
Foxfan88 said:
I am planning 4.10s and a 3000ish stall.
Once you figure out what cam you want, I'd call up a few tech's from different companies and get a recommendation on what stall torque convertor to run. Make sure you install a good tranny cooler as well.
A properly set up automatic will actually work pretty well with a cam that's a little soft downlow on torque. B303 with 3500 stall and 4.10's worked awesome in a 3600lb convertible my friend had.
