How bad is this??
asecretfile
228
Finished installing my new upper and lower on my 87GT. Have not started the car yet the whole time...but read it is best to change the oil after this swap...and when I was draining the old oil about a cup or 2 of coolant came out, then changed straight to oil. One thing I didnt do is drain the coolant before I did the swap, just siphoned a little out of the top where it was puddling so my gasket wasnt going on wet. Remember I havent even so much as turned the key over during this time, and still havent
is a little coolant coming out of the pan terrible news or could it have been from when I took the old upper off and a little leaked in?
thanks
It's probably from the lower intake. When you first start it, keep an eye on the coolant and oil to see if either of them appear to be mixing.
so you think maybe from when I took the old lower off while the coolant level was still full it might have leaked in then? I mean its still almost full now....I only siphoned out maybe 40 oz of it during the install
I took my time and was very careful when placing the gaskets and lower and the torquing sequence
thanks for replying :nice:
