how cold is your ac?
With R134 conversion, I am seeing 55-60 degrees with outside air temps in the 90's. Those are the vent temps with the thermometer stuck directly in the vent, with the fan on high and the A/C running 10-15 minutes.
89stangWhiz said:
Wow, that is awesome. Im looking at high 60's low 70's with those outside temps.
I should have said that those are the vent temps with the thermometer stuck directly in the vent, with the fan on high and the A/C running 10-15 minutes. Soory about the ommision.
I have 134a in mine and it's 85° today with lots of humidity and it gets nice and cool inside my car. I don't know the exact temp, but its very comfortable and starts to get cold enough that I have to turn the fan down a notch on a 15 minute drive. Not too bad, I don't think. :shrug:
I think that the average temp differential for a R134 system in good condition is about 40-45 degrees difference between inside & outside temps.
If your A/C isn't running very cold, there could be many reasons. First I would check the pressures. On a hot day, you should see at least 200psi on the high side and between 20-40 on the low side. If that is all good, and it still doesn't run too well then look at the condencer (in front or radiator) and check the temprature between the inlet and outlet, there should be a significant differece in temprature, and also, very overlooded, be sure the the line doesn't get cold until after the orifice tube. Ford condencers and evaporators can clogg easy, and so can the orifice tube. Dirt can clogg or just restrict any of these and although it may run and cool, it won't quite do the job.
Strype said:
werd...mine works good outta the garage, but once i park in the sun and then get back in, the interior will never cool off untill im goin for like 20 minutes....good thing my house and work have garages lol
it just ain't cold enough.. and it makes the car get up to like 245* <--- not good
