How do I change my differential?
Blue89
California
My '89 limited slip just went out. I was wondering if anyone new of any good links for me to look at on how to change the diff. I have never done this before and was wondering if it was fairly easy. I have access to a lift as well. Also, when I take corners or a 90 deg. turn I hear a "rubbing" noise from the rear-end. Could the diff. be causing this as well? Thanks in advance!:shrug:
real important, everything has to go back on as it came off. Especially when you remve the ring gear. It has marks on it. And there are some other bolts that have to go on the exact same way as well. Oh yea you'll need a diff cover gasket, maybe a rear seal, rtv, gear oil, pump to put oil in, loc-tite (red). Oh and you may need some PB to remove some bolts. It is not really that easy of a job, grab you a chiltons.
You won't really know what you'll require in the way of shims, etc. until you get into it. You should check backlash BEFORE you take it apart. And you should carefully note/organize which shims went where before you start disassembly. Theoretically if you put the shims back in the same place and you leave the pinion gear alone, when you get it back together you should have the same backlash. But you never know until you get in there....
