There is supposed to be a round clip under the piece that you see when you look into the hole when you pull the dizzy out. It is to hold the shaft from coming out when you pull the dizzy. If the engine has not been torn down, or was done by someone being carfull, it will be still there. I have used large tipped angle snap ring pliers to hold the clip, and pull a shaft, and slide another into it while still holding it. Best done with 2 people. If the clip is dropped, it could do damage if not retrived.
