How do i: check timing, check compression?
I dont have any pics, but Timing you need a light of course, pull your spout connector, have engine running, put the little clamp thing on the timing light on the number 1 cylinder spark plug wire, point the timing light at the marks on your hamonic balancer, it will have a pointer off the block and you will see marks starting at usually 10 degrees advanced and at least 15 to 20 degrees retarted, make a note of where its at before you adjust. loosen the bolt holding down the distributor, and turn the dist. slowly watching the timing marks while doiong this, adjust to where you think you want it then tighten the dist, back down, double check your timing and your set. plug the spout connector back in, this will set you base timing, computer pulls timing as rpms advance.
cool, what is a spout connector and where is harmonic balancer and what it look like?
