If the intake is off, it will say 351 in the lifter valley. The heads are about 1.5 inch off the water pump. 289 or 302 heads will be right up close to the water pump. If the oil pan is off the crank on the 2 piece main has 3m cast into it. If you have a 289/302 measure the distance across the intake, the 351 will be about 1 inch wider. The thermostat housing is completly above the w/p and timing cover. 289/302 is partially behind the w/p timing cover.
