How do I know if Synchros are bad?
  • Thread starter Thread starter bbbngowc
  • Start date Start date Jun 17, 2008
bbbngowc
32
  • Jun 17, 2008
My 91 GT is grinding only in 3rd gear.
How can I test/check to know if it's the synchros or something else? I've changed clutch, clutch cable, clutch fork, adjusted clutch and changed to GM Synchromesh. Still grinding.
A
AustinFoxBody
  • Jun 17, 2008
I would think that that would be your problem. Does it grind more when the tranny is cold and get better once it warms up or is it all the time?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jun 17, 2008
  • Jun 17, 2008
Most likely the blocker ring is wearing out.
BTW, GM synchromesh eats the linings and is not recommended in a T-5
Ike83
St. Louis, Missouri
Jun 18, 2008
  • Jun 18, 2008
MY gears grind when they're cold, but then seem to get better when the car warms up. THAT would be a sign of bad synchros, right?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jun 18, 2008
  • Jun 18, 2008
Yup, early signs of blocker ring wear.
Are you running synthetic fluid? If so, replace it with conventional ATF. It's less slick so it will grab more and help prevent grinds. It could fix the issue if minor enough
Ike83
St. Louis, Missouri
Jun 18, 2008
  • Jun 18, 2008
Makes sense to me.
bbbngowc
32
  • Jun 18, 2008
Does it all the time. If I'm cruising and I shift below 2000RPM it doesn't grind. Once I'm at 2000+RPM it grinds.
bbbngowc
32
  • Jun 18, 2008
I had synthetic fluid in, but I changed it to GM Synchromesh.
Ike83
St. Louis, Missouri
Jun 18, 2008
  • Jun 18, 2008
See, that's kind of strange.
With mine, the vehicle shifts fine as long as you shift HARD into each gear. However, if I'm cruising below 2,000 rpms, and ONLY if I'm going from 1st gear to 2nd gear, the shifter will sometimes pop out of 2nd gear and back into neutral. It's like I have to man-handle the shifter in order to get it into 2nd gear without popping right back out at me.
lx93notch
24
coventry, rhode island
Jun 19, 2008
#10
  • Jun 19, 2008
  • #10
may seem dumb but check the shifter an see if its tight cus mine was loose and it was only grinding 1st to 2nd. pulled the bolts out put some loc-tite on them and its been fine since
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jun 19, 2008
#11
  • Jun 19, 2008
  • #11
It's all related to the friction material ont he blocker rings.
With grinding over 2K RPMs, it's due to greater speed differential between gears. When you shift at 2K, it needs to drop maybe 1000 RPM. Less than that and you only need a 500-700RPM drop. There is a magic point where the synchro simply cannot match the speed quickly enough and you grind.
Same goes for shifting fast. Fast shirts put more force on the blocker ring and the initial "hit" can cause it to grab. When you shift slowly, it tends to slip a little bit more.
All signs of synchro's wearing.
And like i said before...it's cheaper to replace it now as you only need to replace the soft parts. Start consistently mashin gears and it gets expensive
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
