How do I properly take off my headliner?
  • Thread starter Thread starter PeteyAce
  • Start date Start date Jan 14, 2008
PeteyAce
346
Jan 14, 2008
  • Jan 14, 2008
I need to get to some wires for the hatch, I need to know the correct way to remove my headliner, and possibly to put on new headliner and reinstall.
NKau
1,346
Jefferson, WI
Jan 14, 2008
  • Jan 14, 2008
I'm assuming the hatch is the same as the notch; you have to pull out the 3" wide metal rails that hold it up on the sides and up by the windshield/back window (they are held in by wierd springy clip things and pull straight out; they are tough, but will come).
PeteyAce
346
Jan 14, 2008
  • Jan 14, 2008
where on the side are these 3" wide rails located?
NKau
1,346
Jefferson, WI
Jan 14, 2008
  • Jan 14, 2008
Right above your window frame from inside the car.
skunk21
1,203
Taxachusetts
Jan 14, 2008
  • Jan 14, 2008
to take out the headliner first remove pull the fuse for the interior lights. remove the seat belts and back seats so you can get to the big quarter panel trim and lay the over or remove. drop the map light and dome light un plug and remove. next remove the trim piece over the doors(between the a-pillar trim and rear quater panel) which is clipped in. next take out the trim piece at the windshield which also is clipped in, then remove the a-pillar trim which has screws and clips(becareful the clips snap easy). remove the trim piece by the hatch which is screwed in then remove all the screws holding the quater trim panels in and rear speakers. drop the head liner down and angle it out the door reverse to install. I may be missing some small stuff I'm trying to remember of the top of my head but that's the jist of it. best of luck.
O
1978 Mustang II Headliner Install
  • onusideburns
  • Nov 4, 2025
1974 - 1978 Mustang II Talk & Tech Mar 9, 2026
Enzio
Exhaust April is the worst month
  • Enzio
  • Mar 4, 2026
1974 - 1978 Mustang II Talk & Tech Mar 7, 2026
LILCBRA
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
D
Rust on Window Belt
  • DuluthFoxbody
  • Nov 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 4, 2026
DuluthFoxbody
D
Sunroof Woes
  • TIGGER
  • Feb 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2025
Snakbytn1990
