I guess this sort of a newb question. Sine I figured out that my stock guages and the autometer cluster is useless for oil pressure, volts, and water temp I want real guages.
I will use Autometer Phantoms (electric) with a triple full a pillar. I've seen the threads that show the location for the oil pressure sender, but I haven't seen the water temp location or volts.
My questions are:
1. I have no idea where to route the signal wires so I can get them to the pillar. I am assuming I have to go through the fire wall, so is there a preferred location to do that? And how big of a hole do I need? I'm also assuming the steel will be tough to drill through.
2. If there is only one location for the water temp sender and I disconnect the original will it trip an error code?
Thanks in advance
My questions are:
Thanks in advance
