How do you adjust a timing chain to get +-4*?
The cam gear that comes with the chain is cut to accept a 4* advanced or retarded position, right?
If so, install the gear just like you would, accept lining up the keyways for the 4* advanced or retarded position, which ever you choose.
Joe
Are you using the stock gears and chain? If the yes, then you need to buy a new set!!! They are cheap...a FMS kit is like 65$ from sumitt. It has 9 diff keyways. You don't want to use the old set. They strech over time and won't give you correct timming!
