  • 1994 - 1995 Specific Tech
How do you adjust the timing???
  • Thread starter Thread starter wannabecobra
  • Start date Start date Aug 22, 2004
W
wannabecobra
  • Aug 22, 2004
I have been having an acceleration problem with my car for about a month now. The car idles irraticly and hesitates and stumbles when it hits 3000 rpm, and the car will barely pull past 3500. I hooked up a code scanner to her and got back a code 181, and 189 which says : Fuel system at rich adaptive limit at partial throttle / system lean.
If the car was running rich I don't think it would idle rough or stumble the way it has been. Not too mention I would smell it.
So either I am sucking too much air or am not getting enough fuel. I know that this could be attributed to a variety of problems like clogged injectors, weak fuel pump, clogged fuel filter, bad intake manifold gasket etc...
I know its not the fuel filter because I changed it last week.
I figured before I dove into more expensive problems I would check on the timing.
If anyone has any ideas I would love to hear them.
Thanks guys
H
HazMat404
1,749
Aug 22, 2004
  • Aug 22, 2004
do a quick search on "timing" in the 94-95 specific section. promise you will get at least 10 different threads and probably each will tell you exactly the same.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
