How do you get the stock tb and egr off!!!!!!
Jo_885o
422
Clint. Twp, Michigan
I'm putting the motor in sig together and cant get the damn stock tb off. I'm going with a 70 mm tb and egr but the reason i'm taking it off is to get the studs. i need them for the other tb and egr right? its on there pretty tight. I wondering if pb blaster would loosing things up a bit. The intake is off by the way. Thankz Jo
WantaGT said:
i had to heat up the egr spacer and wedge a screw driver in between it and the intake, after heating continuously and prying it came off revealing rusted studs.
WantaGT is right on...awhile back I was changing my intake and couldn't get the screws out that hold the plate on the top so I could get to the 2 long bolts inside. I rounded the heads off of every T-20 torx driver I had even while using Blaster. When all else failed, I took it for a 15-20 min.ride and got it hot. Opened the hood and presto, the screws came right out! :D
