how do you make youre car lighter?
Dont go too crazy with weight reduction...
Every 100lbs lost is 1/10th gained in the 1/4 mile. I rather have my AC, rear seat (cramped... but it serves its purpose...), and sterio than be 1/10th faster at the strip.
It does more for handling IMO, the car would be easier to toss around then.
Here is a list of mods with the weight loss......my car weighs 3250 with me in it and is a daily driver!
ENGINE:
- STOCK 4.6L SOHC MOTOR
- AFM 4" POWER PIPE/ K&N FILTER
- BBK 75MM THROTTLE BODY
- BBK UNDERDRIVE PULLEYS
- BBK 1 5/8 LONG TUBE CERAMIC HEADERS
- C&L 85MM MASS AIR
- SVT 24LB INJECTORS
- CUSTOM SCT DYNO TUNE (264RWHP/304RWTQ)
- MEIZURE ELECTRIC WATER PUMP
- PLASMA BOOSTER IGNITION
- ACCUFAB PLENUM (PORTED AND SMOOTHED)
- 1/2IN PHANOLIC INTAKE SPACER
- 2.5IN EXHAUST W/BBK H-PIPE AND MAGNAFLOW EXHAUST
- AEM'S WIDEBAND UEGO CONTROLLER
- BBK TIMING ADJUSTER
- STEEDA CATCH CAN
- 180 DEG POWER STAT
- STEEDA 190LPH FUEL PUMP (BOSH)
- STEEDA HIGH FLOW FUEL FILTER
DRIVETRAIN:
- AODE 4R70W TRANSMISSION LEVEL II REBUILD
- TUBULAR FRONT SUSPENSION W/COIL OVERS (SAVES 90LBS)
- TRANSGO SHIFT KIT STAGE III
- MOTIVE 410 GEARS
- 3200 PI TORQUE CONVERTER
- RACE CONCEPTS SLOTTED/DRILLED ROTORS
- HAWK PERFORMANCE BRAKE PADS
- FRPP ALUMINUM DRIVE SHAFT (SAVES 20 LBS W/O STOCK BALLANCER)
- STEEDA ALUMINUM LCA’S (SAVES 25LBS WHEN REMOVE QUAD SHOCKS)
- TA REAR GIRLDLE
- POLY MOTOR/ TRANS MOUNTS
INTERIOR:
- CUSTOM PAINTED INSERTS – CUSTOM WINDOW TINT
- YMR REAR SEAT DELETE KIT (SAVES 45 LBS)
- X2C FRONT RACING SEATS (SAVES 110LBS)
EXTERIOR:
- EAGLE 17X9 ALUMINUM RIMS - MACH 1 CHIN SPOILER
- MT DR'S (27540R17 OUT BACK) - MACH 1 GRILL DELETE
- FUTURA (24540R17 UP FRONT)
FUTURE MODS:
- COBRA R HOOD (SAVES 20 LBS) - VT STAGE II CAMS
- STEEDA UCA’S (AWAITING INSTALL) – STEEDA FULL LGNTH SUBS
- LAKEWOOD 50/50 ADJUSTABLE REAR COIL OVERS (AWAITING INSTALL
"ED"
mustangkid05 said:
no idditn get the lottery money i owned you guys lol.......yea that seems like alot of work just to loose .1
how do you consider being a liar and an idot owning someone. This isn't recess at kindergarten...i know i will be blocking you and so should everyone else. Stupid kids.
:stupid: .
Why would you go on a forum and lie about winning money, owning a V6, then GT, then a cobra and using god knows how many differnt names. Someone needs to grow up. :nonono: Im blocking him also.
i think mustangkid 05 is one of those ricers wanna bees on the civic forums that trashes mustangs then comes here to find out what we do.. prolly doesnt even own a car.. some people need to grow up.. hey did you guys know i won the lottery too!!!!it was 2 bucks on a scratch off ticket does that count? lol...
:bs: . :D
