How easy is it to remove ECM?
tomazzo
12
Shreveport, La
I keep getting code 15 from my ECM...general opinion is the ecm is bad. What does it entail to pull the ECM? I pulled the kick panel, and It is awfully tight in there. It looks like I have to pull the ac/heater blower assy to the to the ECM. Is that necessary?
Remove the passenger side kick panel. Remove the electrical connector with a 10 MM socket. Remove the insulation & padding and in the lower RH coner of the strap that holds the computer in place is a single screw. Remove the screw and the computer can be wiggled out of its resting place.
