how fix code 15??
HISSIN50
33
129
Gooch, Jrichker hit it pretty well on your other thread. It means the puter is not getting constant (battery power). But if you have constant power to pin1, that indicates the puter might be bad.
If you dont have constant power to pin1, chase bad wires. this wire supplies the puter with constant battery power so it does not have to relearn adapted strategies each time you start the car.
good luck.
HISSIN50
33
129
gooch06 said:
So that wire runs from the battery to the computer?
which wire? Pin 1 on the computer's wiring harness is constant battery power.
the FP relay wire you are having issues with sounds like the ground from the computer to the FP relay.
I was thinking that someone might chime in about how to remedy the FP relay, but no one really has. If you search TMoss' old posts (or search for people with computer and/or no fuel pump activation issues), there was a thread some time ago where Tom was talking about remedies for a lost FP ground pulse. (I might have just grounded the wire, but did NOT want to suggest that since I dont have a mastery of the system like others do).
BUT, now that you also have this issue, I would get access to the puter (remove pass kick panel) and start probing terminals to see what is going on (now that you possibly have a couple inputs and outputs not doin what they should be). Your puter might have taken a poop, but you need to be real sure that the wiring is sound before you put a new one in, or you can fry the new puter. Jrichker, TMoss, et al are much better at this stuff than I.
My two cents.
good luck.
