93steeda said:How good is MSD ignition and how hard is it to install?
latham83 said:They work pretty good dude..I'd reccomend it to anybody...I hooked one up and i could feel a bit of a dif in throttle response...it should def. help ya out in some way...
staticc said:well i sure hope its alot better than stock, i just spent ~1000$ on a whole new ignition setup with msd stuff & 24lb injectors![]()
88POSLX said:As Heckon4whls pointed out... on a chassis dyno you will see no gains from an MSD on a stock or mildly modded motor with a properly functioning factory ignition. You need to increase cylinder pressures to see any benefit.
