- Nov 26, 2005
- 100
- 0
- 0
ive never tried to remove them or seen it been done, so i really have no idea. i might be getting some 24lbers and a mass air soon, so i want to make sure i wont mess anything up. any special tricks?
dragnazz5.0 said:no special tricks just make sure that all the o rings come out of the fuel rail with the old injectors. if they dont, just take a small screw driver and pop them out. they just pop off the fuel rail and pop out of the intake. good luck
CarFreakGT said:On a semi-related topic: I have considered the same thing. I have an opportunity to get some 24# injectors for a good price. Is it even worth the trouble on a stock engine. 125K miles w/ only mod being full new exhaust w/ 130 amp alt. and electric fan to be installed soon. Would I notice a difference, or better to hold off for now? Thanks.
I searched google and found this:CarFreakGT said:On a semi-related topic: I have considered the same thing. I have an opportunity to get some 24# injectors for a good price. Is it even worth the trouble on a stock engine. 125K miles w/ only mod being full new exhaust w/ 130 amp alt. and electric fan to be installed soon. Would I notice a difference, or better to hold off for now? Thanks.
BOWTIEKILLR said:thanks for all the replies guys. so i do have to take the upper off?
90lxfoxbody said:i bought a fuel injector rebuild kit off ebay for $21 - even came with one spare of each part. removal and rebuild was a breeze, and i was stunned at how much difference i could tell. the 24 lb injectors should really wake your car up if you have alot of other mods.
dec322 said:Why did you buy the rebuild kit? The reason I'm asking is b/c I've got some major leaks from my injectors and I know its coming from the top portion of the injector (close to the fuel rail). I thought I had to replace the injector but if I can just rebuild it....I will.
Thanks
dec322 said:Oh....I didn't know they could crack. Well, I think I'm just going to buy some injectors from a reputable person on ebay. They've got some ford motorsports injectors with new o-rings and pintle caps for a pretty good price. Assuming that the person is honest and the injectors aren't cracked.
89lxsport50 said:I bought a set of 8 Ford Racing injectors from Summit for around $210 a while back.
