How involved is the manual steering rack install?
sirr0bin said:
And with flaming river you can get a quick ratio rack
Refresh my memory, quicker ratio means less turns of the steering wheel for the same amount of turning, right?
Also, when ditching the PS pump, just get a shorter belt? What size (I got AC and air pump)?
Thanks for all the answers.
Yes, less turning of the steering wheel. But you must remember, the quicker the ratio, the more effort to turn w/ manual steering.
As far as belts go, you can just run the shorter belt.
The best way to measure belt length with a string and buy that length belt for a K6 belt. (K6= number of ribs)
Original Owner said:
As these guys said, it's an easy job. You'll have to remove the tie-rod ends from the spindles, which required a simple puller ($12 at Murrays, CarQuest or Autozone) or you could beat on the top of the threads after you remove the nuts (don't recommend, but it will work in a pinch).
For future reference:
Leave the nut on 2-3 threads before you beat on the rod ends with a hammer. Not doing this has a high likelyhood of damaging the threads. I know you have to change the tie rods with the 79-81 rack but just don't want someone to read this and beat up the threads on a part they are gonna re-use. Not just in the tie rod threads case here but, use this method in general.
