how long will a build block last under boost?
ADRENLN
2,342
NJ
im just looking for an average time, mile wise. if it were like a built engine from mph or vt and you were running a blower with about 10 -12 psi of boost. what do u guys think, how many mikes?
somthing else to think about, would it last longer under a kb or a novi at the same psi? or would it be the same
one more, how long do blowers themselves last (miles wise) under boost before they blow out?
thanks guys for any info :nice:
first off its not just 1 question, so if you dont like the first one answer the third one :D
i just trying to find out if a built short block will only last 20000 miles or if it can get up to 80000+? just to get an idea what built motors under boost last.
many that already have this can just tell me how many miles you have so far.
i thought the point of the built engine was so you can rev it high with no worries????
the centri doesnt start to make power till high rpm. i just want the strongest engine i can get that will stand up to 112 psi and some higher rpm driving and last some good long miles also. is there a motor like this or what?
these Q's really get you thinking but to answer one Q : i would guess that the blower would have an effect on the block like with the KB as soon as you give it gas you have instant boost and the centri starts to make boost at around 3000 rpm but the boost level is still lower than the KB at that RPM. So i think that the KB would have more of an effect on the block than the centri because the centri makes full boost at higher rpm's....... but that is one way of looking at it but thier are many different scenarios that play in affect here. :D
It SHOULD go 100K + with ease. Even if you beat on it alot...the only thing you would need to do at that point is re ring the motor and maybe do a valvejob on the heads....a simple overhaul. It probably wont last as long as the N/A stock 2V, just because of the rings....but the bootom end will be good darn near forever.
thanks guys! i know theres no right answer, just like theres no answer to how long a n/a stock engine will last. just woundering what possably an life expectency would be on this type of engine. (ball park figure) thank you to the guys that gave their thoughts.
how about a blower? how long can these things go before the have to be rebuilt or whatever?
Life span depends on too many variables. I've seen 100k plus 5.0l combo's. I've also seen a 4v that went out within 20k. Both were stock shortblocks. Just depends on how you treat it. If you treat it like a race engine it'll last like a race engine if you treat it like a regular engine it'll last like one.
Between the 2 that is a real good question. At first I would think the Kb would be worse just because you would be in more boost more often, but inversely you wouldn't need to spin it as high which seems to be the 2v's downfall.
As far as blowers go I've heard the same on them it seems that the higher boost levels wear them quicker. But with how affordable it is to have most rebuild it shouldn't be a huge concern. Average price I've heard is 300 bucks btw.
well it makes me think about factory blower cars. lightning, 03 cobra, even the saleen and roush supercharged. now i realize that they are run under lower boost and the cobra is forged, but those cars are expected to last a normal lifespan.
what really gets me is the saleen and roush with no forged internals last at those power levels for a normal car expectency life. :shrug:
roush stage 3 rated at around 380-400 hp. what is that to the wheels 350. i mean they have to be running some kind of boost to get the car to be putting 350 to the wheels. i know im shooting higher, but im just talking about this concept for a sec.
roush=
350 to wheels on stock engine for full life....what am i missing
ADRENLN said:
i just want the strongest engine i can get that will stand up to 112 psi .... is there a motor like this or what?
You'd need an engine built out of Wolverine's Adamantium to handle 112 psi of boost. That or give NASA a call and they might be able to lend you some plates off the bottom of the Space shuttle since it seems they keep losing them.
Dan_Soprano said:
Alot of it will have to do with the tune and your driving style. Get a good dead on tune, and keep the RPM's down, she should live a LONG life! :nice:
Dan_Sporano, or anyone else,
Please tell me how you know if you get a "dead on" tune? In a few days I am getting my 99 blown GT dyno-tuned. It has a built engine and has about 8k miles on it since. I'd love to get a dead on tune, but I know nothing, so I guess I will depend on the shop.
Thank you,
Brent C
ADRENLN said:
...many that already have this can just tell me how many miles you have so far. i thought the point of the built engine was so you can rev it high with no worries???? the centri doesnt start to make power till high rpm. i just want the strongest engine i can get that will stand up to 112 psi and some higher rpm driving and last some good long miles also. is there a motor like this or what?
If your engine is healthy you don't need a built block to run 12psi on a centri. A built block allows you to run more rpms safely, and will hold up under more HP than a stock longlock at the same rpms.
Running 12 psi on a centri or 9-10 psi on a KB, with an intercooler and safe tune would be fine on the stock longblock. To be safest, shift points should be no higher than about 6300 because the stock rods are vulnerable at high rpms. For the longest I was shifting at 6500 with 380 rwhp. Some tend to think that intercoolers are not worth the expense, but I've seen enough casualties that could have been prevented if an I/C had been in place. Some of the owners of these broken engines were well versed on tuning parameters, and the dangers of detonation, but somehow thought they would be safe. A built block will also break under detonation, it just takes longer.
BTW, it is incorrect to directly compare psi on a KB to psi on a Novi (or other centrifugal S/C). The KB pushes more air at a given psi, but that results in more heat. The highest psi a KB can run on pump gas is lower than the highest psi that a centrifugal can run on pump gas.
I've been running a Vortech on a stock shortblock for over 4 years and for a total of just under 40,000 miles blown (total miles 46,600+). The 12 psi pulley has been on for somewhere near 3 years with an intercooler. As far as my driving, if I could do it all over again I wouldn't be so abusive . The reason it's held together this long is that the tuning leaves a margin for error against detonation. Detonation is what kills most of the engines we end up reading about. I'm now at 416 rwhp (equivalent to 438 rwhp on a manual car). There are others such as a guy at Corral.Net that has been racing for over 4 years on a Vorteched stock longblock, now with 434 rwhp at 14psi. There are 2 other 2v 99+ GTs confirmed to have run 500+ sae rwhp on stock shortblocks. One was a magazine project car and the other is owned by a member of one of these forums (I believe the Corral).
I've read testimonies from owners with 80 to over 100k miles on the same S/C. Of course blowers can be abused (overspun etc.) or not maintained properly which could cause them to fail prematurely.
registered said:
..Please tell me how you know if you get a "dead on" tune? In a few days I am getting my 99 blown GT dyno-tuned. It has a built engine and has about 8k miles on it since. I'd love to get a dead on tune, but I know nothing, so I guess I will depend on the shop...
Your tune should be such that it leaves a margin for error. You need a good air/fuel ratio AND safe amount of timing advance. One big problem I've seen over the years, is that even some experienced tuners are too agressive with timing advance. One degree off might bring you a bit more power but that can be enough to break your engine (via detonation). How accurate the tune is depends on the specifics of your setup.
Thank you!
