  • SN95 4.6L Mustang Tech
How long will this take
  • Thread starter Thread starter Get E Up 98
  • Start date Start date Apr 13, 2005
Get E Up 98
144
  • Apr 13, 2005
I just bought a new Intake Manifold for a 98 GT. I have to replace the factory one since the thermostat housing is cracked (since the ford geniuses thought it would be cost effecient to manufacture it as a piece of plastic) So how long will it take to remove the old one and put the new one on? And is it a pain in the butt to do?
d98gt
4,505
59
204
SE Texas
Apr 13, 2005
  • Apr 13, 2005
We are pretty much in the same boat
http://forums.stangnet.com/showthread.php?t=534549 tells some things about it and gives some links.
I hope I somewhat helped
Gunfighter
186
Grapevine, TX
Apr 13, 2005
  • Apr 13, 2005
probably an hour or ss if you take your time and have the right tools
d98gt
4,505
59
204
SE Texas
Apr 13, 2005
  • Apr 13, 2005
Im thinking it's going to be longer than an hour.
My install will be started around 4:30 Friday and hopefully I'll have it finished before it gets too dark (7:30 or so).
I'll also have a rental car just in case something doesn't go correctly
Get E Up 98
144
  • Apr 13, 2005
Wellim going to tackle the task of installing the new intake, new shocks and struts, new brake pads and changing the oil. So we shall see how long it takes...Ill try and get some before and after pics...the new intake I have came with everything, new alternator bracket, gaskets and such. Its also got the aluminum crossover and not that cheap crap. So good luck to us
M
modmonster
43
  • Apr 13, 2005
Yeah dude as long as you take your time and do everything right a little over an
hour is definately not out of the question.
d98gt
4,505
59
204
SE Texas
Apr 13, 2005
  • Apr 13, 2005
Get if off of Ebay for $199.99 + 20 shipping? That's what mine ended up being.
Came with EVERYTHING.
My plan is to remove intake, clean everything up under hood, put new intake on, change wires/plugs and hopefully everything goes well.
Install sounds easy, but those are the kind which usually go wrong
Get E Up 98
144
  • Apr 14, 2005
Yeah mine ended up being like $200 shipped I believe. Since the old one leaked so bad im going to have to clean up mine as well. What would be the best thing to use to clean up the engine to remove some of the antifreeze stain?
GDawg
1,469
Nevada
Apr 14, 2005
  • Apr 14, 2005
It took me a little over two hours but then I took pictures and went pretty slowly to make sure I knew where everything went as I pulled stuff off.
Here is some of the pictures I took while doing mine...
http://community.webshots.com/album/72370370hPeenK
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
squeak93
C
Bored with my 73
  • Curtis Harper
  • Apr 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 23, 2026
RaggedGT
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
