This happened to me shortly after purchaseing my mustang. The previous owner had recently done a "performance rebuild" on the 351W, and the car seemed healthy and powerful.
I decided to give the car a tune up even though it was running pretty good. Gave her a complete fluid change and Replaced cap, rotor, points, plugs and wires.
After the tune up, I fired up the car to do the timing but was greated with a horrible miss and backfireing.
Here's the troubleshooting steps I took:
1) Double checked firing order, and ensured it was correct.
2) Replaced plug wires, double and triple checked connections.
3) Put old cap and rotor back on.
4) Tried a different ignition coil. Eventually even swapped in a different distributor.
5) Tried new plugs.
6) Swapped old points back in.
7) At this point I was confused as hell. Did a compression test, everything was fine.
8) Pulled off valve covers to check valve train, turned engine over by hand, Everything appeared fine.
I spent days trying to figure this one out. I was confused as hell as to why the car was missing and backfireing. It would barely idle. Even had a few friends who were good with engines come over to see if they could figure it out. They were as confused as I was.
Anyone want to hazard a guess as to what my problem was?
5) Tried new plugs.
