Brackets:
*accessory backing plate (mounts all accessories on pass. side) (like a mini version of the stock accessory bracket)
*accessory front plate (holds blower head - it is flat with a big curved arm on the right side)
*drive belt tensioner mount (kinda looks like an igloo. a little square on one side, and a little leg on the other.)
*blower belt tensioner mount (odd-shaped, has two areas that are adjustable tension bolt holes, kind of making a semi-circle shape)
The "Alternator Stay" is a piece of curved metal that comes bolts in between the alternator and the main acc. bracket to keep it in place. You can rig something up to work, otherwise I doubt you will find that piece anywhere else.
Are you looking at a used kit, trying to see if everything is there?
