shttygtstang said:
10 psis ? with a 8.5 compression i know i dont know about stangs buti know about adding boost you can boost alot more pressure than that
14.7 psi is the atmospheric pressure, SO, if you boost a motor with 14.7 psi, you will technically DOUBLE the output of power, as long as you have the supporting parts, ie: fuel, spark managment, intake, exhaust ect ect ect...SO, for example, a 302 (225hp stock)with well flowing heads and intake, with high flowing injectors, boosted to 14.7 psi, should in theory make somewhere around 450- 500 FLYWHEEL horsepower, which translates to approx 400 rear wheels hp, WHICH the majority of guys on this sight have, by doing the above combination. My engine in particular, flows REALLY well. The heads are stage 3 ported twisted wedge with off the chart flow numbers, and iv got an unrestricted exhaust(long tube headers, no cats). I have a 14lb pulley on my supercharger, and as we know PSI stands for Pressure per Square Inch, so...Since my motor flows so well, ( good heads and intake) I will never actually see 14 psi on my boost guage, becuase the motor is using that air before it has time to build PRESSURE(per sqaure inch). However, I am still injesting the same amount to CFM, or, volumetric air into the motor. So in conclusion, I only see about 7-10psi on my guage, but the power output is the same as someone who would be squeezing 14psi into the restrictive combination causing more stress on the motor. any questions?
