How Men and Women change thier oil
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
Oil Change instructions for Women :
1) Pull up to Jiffy Lube when the mileage reaches 3000 miles since the last oil change.
2) Drink a cup of coffee. < BR>3) 15 minutes later, write a check and leave with a properly maintained vehicle.
Money spent:
Oil Change $20.00
Coffee $1.00
Total $21.00
Oil Change instructions for Men:
1) Wait until Saturday, drive to auto parts store and buy a case of oil, filter, kitty litter, hand cleaner and a scented tree, write a check for $50 .00.
2) Stop by 7 - 11 and buy a case of beer, write a check for $20, drive home.
3) Open a beer and drink it.
4) Jack car up. Spend 30 minutes looking for jack stands.
5) Find jack stands under kid's pedal car.
6) In frustration, open another beer and drink it.
7) Place drain pan under engine.
8) Look for 9/16 box end wrench.
9) Give up and use crescent wrench.
10) Unscrew drain plug.
11) Drop drain plug in pan of hot oil: splash hot oil on you in process. Cuss.
12) Crawl out from under car to wipe hot oil off of face and arms. Throw kitty litter on spilled oil.
13) Have another beer while watching oil drain.
14) Spend 30 minutes looking for oil filter wrench.
15) Give up; crawl under car and hammer a screwdriver through oil filter and twist off.
16) Crawl out from under car with dripping oil filter splashing oil everywhere from holes. Cleverly hide old oil filter among trash in trash can to avoid environmental penalties . Drink a beer.
17) Buddy shows up; finish case of beer with him.
Decide to finish oil change tomorrow so you can go see his new garage door opener.
18) Sunday: Skip church because "I gotta finish the oil change." Drag pan full of old oil out from underneath car. Cleverly dump oil in hole in back yard instead of taking it back to Kragen to recycle.
19) Throw kitty litter on oil spilled during step 18.
20) Beer? No, drank it all yesterday.
21) Walk to 7-11; buy beer.
22) Install new oil filter making sure to apply a thin coat of oil to gasket surface.
23) Dump first quart of fresh oil into engine.
24) Remember drain plug from step 11.
25) Hurry to find drain plug in drain pan.
26) Remember that the used oil is buried in a hole in the back yard, along with drain plug.
27) Drink beer.
28) Shovel out hole and sift oily mud for drain plug. Re-shovel oily dirt into hole. Steal sand from kids sandbox to cleverly cover oily patch of ground and avoid environmental penalties. Wash drain plug in lawnmower gas.
29) Discover that first quart of fresh oil is now on the floor. Throw kitty litter on oil spill.
30) Drink beer.
31) Crawl under car getting kitty litter into eyes. Wipe eyes with oily rag used to clean drain plug. Slip with stupid crescent wrench tightening drain plug and bang knuckles on frame.
32) Bang head on floorboards in reaction to step 31.
33) Begin cussing fit.
34) Throw stupid crescent wrench.
35) Cuss for additional 10 minutes because wrench hit bowling trophy.
36) Beer.
37) Clean up hands and forehead and bandage as required to stop blood flow.
38) Beer.
39) Beer.
40) Dump in five fresh quarts of oil.
41) Beer.
42) Lower car from jack stands.
43) Accidentally crush remaining case of new motor oil.
44) Move car back to apply more kitty litter to fresh oil spilled during steps 23 - 43.
45) Beer.
46) Test drive car.
47) Get pulled over: arrested for driving under the influence.
48) Car gets impounded.
49) Call loving wife, make bail.
50) 12 hours later, get car from impound yard.
Money spent:
Parts $50.00
DUI $2500.00
Impound fee $75.00
Bail $1500.00
Beer $40.00
Total - - $4,165.00
But at least you know the job was done right!
Funny joke and i get the punchline. But man would I ever like to be in complete disagreement on "properly maintained vehicle" and "jiffy lube" being in the same sentence. I worked there in Hs and its nothing but retarded flunkys who have no auto experience at all either learning or jus attempting to perform simple easy service work on your car. The amount of things I saw messed up on customer cars, albeit expensive one at that... I could write a book about it. I despise Jiffy Lube and as a dealer tech, I view Jiffy Lube as a total disservice to the auto service industry. They make money effin up all the easy gravy work leaving reputable garages with headaches.
What I gather from this:
1) By omitting beer, time, money, and energy would be saved - especially in that example.
2) The oil filter was probably tightened too much when installed last. Hand tighten the filter and it will be ok; I've never had to use an oil filter wrench providing I did the last oil change on that vehicle.
3) Use a socket and ratchet to loosen the oil pan drain plug; if you do slip, at least your hand won't hit anything, thus saving your bowling trophies.
4) Why would you place a case of oil under your car? Most of us use the fill hole in the passenger side valve cover to fill the engine with oil. Better yet, buy a 5 qt jug of oil. You can then pour the oil from your drain pan into the empty 5 qt jug and return it to autozone for FREE environmentally-friendly disposal.:flag:
5) Probably don't need to test drive the car, especially if you have been drinking that much beer. Starting the car up and ensuring proper oil pressure and no leaks would probably be sufficient:nice:
MOST IMPORTANTLY: I REALIZE THIS THREAD WAS STARTED AS A JOKE, AND THE ORIGINAL POSTER PROBABLY ISN'T THE AUTHOR OF THE INSTRUCTIONS. I simply responded for those who actually may use those methods of changing oil.
On a side one time in a company vehicle, we got the oil changed at Jiffy Lube. We got about 50 miles away and discovered Oil on the back window of the early 1990's Izuzu Trooper. How that happened, I'm not sure, but I think they forgot the dipstick, although that still doesn't explain the oil on the back window.:shrug:
