How much better is the E cam than the B cam
  • Thread starter Thread starter Kdubslugga
  • Start date Start date Dec 3, 2006
1 of 2 Next Last
Kdubslugga
1,515
Akron, OH
Dec 3, 2006
  • Dec 3, 2006
Im doing a cam soon and when I do it I'll have Edelbrock Heads, 1.90/1.60, Powerdyne Bd11a 9lbs., 75mm Mass air and 30lb injectors, Cobra Intake and all the bolt ons. Im stumped between the B cam and the E cam, i dunno what to get. Now I know these are the best all around cams out there so Im not looking for that I just wanna know if the E cam is that much better than the B cam. I have 1.7 rockers so piston to valve clearence is something that ive been looking into. With an B cam and the 1.7s Id have .510 of lift which is pretty equals out to an e cam but with a longer duration. With an ecam and the 1.7s Id have .528 of lift. Pretty much Im asking how much more would an E cam help me rather than a B cam?
FSTRDNU
76
  • Dec 3, 2006
off topic, but i'd run a tfs cam.
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Dec 3, 2006
  • Dec 3, 2006
The B is the better cam..
bubba-dough
1,044
Indiana
Dec 3, 2006
  • Dec 3, 2006
To keep with your request and not mention another cam.....I would go B cam.
O
OrLackThereof
560
Palm Bay, FL
Dec 3, 2006
  • Dec 3, 2006
Apples to oranges.... E is more streetable, better for blowers, more lift less duration, better for stock-stalled auto transmissions. B is higher rpm, more duration less lift, better for N/A, probably makes more peak power, rougher idle, needs a 5-speed or a mild stall converter.
For your combo, I'd go with the B. The 1.7 rockers will make up for the lift and you'll have a pretty stout little camshaft, and you have a 5spd so converter wont be a concern.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Dec 3, 2006
  • Dec 3, 2006
I'm not that up to speed with cam tech but wouldn't more lift be better for higher RPM?
O
OrLackThereof
560
Palm Bay, FL
Dec 3, 2006
  • Dec 3, 2006
Yes but thats not the only variable. LOTS of things to keep in mind...the lift, the duration, the lobe separation angle, the ramp-rate on the cam, the overlap.....
More duration will make the cam idle rougher and perform better in higher rpms....lift will make it perform better in higher rpms also but not really affect the idle quality. Also LSA has a big effect on idle, a tight LSA can make a small cam behave big, and transversely a wide LSA can make a bigger cam behave smaller and more computer friendly.....
The E-cam is more streetable largely due to its lower duration and wide LSA (114 IIRC). The B cam has a good bit more duration and Im pretty sure it has a tighter LSA (110 or 112 IIRC)
Im not trying to sound like a total expert here, and there's WAY more left on the table as far as cam design, but that's some basics... And just look up opinions on the B cam from experts, then on the E-cam, theyre very easy to find....hell I believe this website has reviews even, you'll find the B is listed as rougher idle and higher powerband, where the E is listed for smoother idle and streetability as well as being a good entry-level blower cam
Kdubslugga
1,515
Akron, OH
Dec 3, 2006
  • Dec 3, 2006
Ok thanks guys, your answers were what i was looking for!!!
310stanger
170
  • Dec 3, 2006
Not for nothing but id pick neither. Get a tfs stage 1 cam. Its even cheaper then both the b and e cam. those cams are outdated technology. the tfs stage 1 makes more power.
Speeds8erM-1
1,240
Pensacola Florida
Dec 4, 2006
#10
  • Dec 4, 2006
  • #10
I frown on this thread.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Dec 4, 2006
#11
  • Dec 4, 2006
  • #11
Alot of time, effort, money tied up in that combo of parts...don't sell yourself short on the bumpstick, custom.
soontobefastfox
275
Troy, Michigan
Dec 4, 2006
#12
  • Dec 4, 2006
  • #12
+1 The ford cams are way outdated, you can do so much better! Go custom or a company like Comp, Crane, TFS, etc.
payupsucka
324
Keeping it grimy in Fall river MA.
Dec 4, 2006
#13
  • Dec 4, 2006
  • #13
get and anderson motorsport b 21
ExplodingGopher
517
The mistake on the lake (Ohio)
Dec 4, 2006
#14
  • Dec 4, 2006
  • #14
TFS1 cam, what i'll be using probably when the 5.0 gets rebuilt again, scrapping the B-303 that was in there.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Dec 4, 2006
#15
  • Dec 4, 2006
  • #15
whats the deal with ford cams being outdated and getting the shaft. Sure they are old, but they perform great and people still use them today after like 20 years of being out there. u can grab an alphabet cam CHEAP they are great buys!
O
OrLackThereof
560
Palm Bay, FL
Dec 4, 2006
#16
  • Dec 4, 2006
  • #16
They definitely get the job done, but there are better options out there. I think a lot of their popularity is from their price, availability, the fact that EVERYBODY knows what a B, E, F, Z, X, cam is....and you can find them in good used shape for next to nothing all day long. I ran an E once, wasnt disappointed in it but I knew I was leaving a few ponies on the table too
Speeds8erM-1
1,240
Pensacola Florida
Dec 4, 2006
#17
  • Dec 4, 2006
  • #17
This thinking is why poor 5.0 guys getting their confidence built up from these boards go out to the local races looking to pick on some bo bo LS1 which in turn proceeds to rape them. Then they get back on here wondering why they lost to a mullet car with headers.
Funny how you go to the LS1 boards and they are ALWAYS changing stuff with cams and stuff and always making more power, yet the average 5.0 guy is content with running an old school cam, making 260-280 rwhp (not all but average) and being content just before "it was more than stock".
soontobefastfox
275
Troy, Michigan
Dec 4, 2006
#18
  • Dec 4, 2006
  • #18
+1 that's why I'm so sick of everyone talking about the ford cams for the same price or more you can get a much better cam! I don't understand
BOWTIEKILLR
100
#19
  • Dec 4, 2006
  • #19
anderson in what in going with...they seem to make some good grinds
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Dec 5, 2006
#20
  • Dec 5, 2006
  • #20
i chose a B-cam because i got it in a deal for a GREAT price, plus it was more than enough for my thumper and tmoss combo. i dont care what some joe schmoe in his ls1 runs or how fast, i work on my car for my own enjoyment and i know what i can and cant beat. i rebuilt my engine with this cam and stuff for simply a nice street car that has some get up... i'm not all balls racing guy looking for every ounce of power.
sure i could have went and bought a nicer grind like TFS stage 1 or something, but i already had one to suit my needs. so why bother. it would have made maybe a 10 hp difference which wouldnt have been felt anyways.
plus i dont see whats wrong with my way of thinking, i just commented on there are other cams out there that are easier and alot of times cheaper to grab a hold of. i wasnt putting down the good cams or anything.
if the FRPP cams were THAT bad then they would be long gone and ancient history but a good portion of 5.0s still utilize alphabet cams. i dont see whats wrong with it....
1 of 2 Next Last
SBF Head Flow Table - Work in Progress
  • Noobz347
  • Sep 29, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 30, 2025
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
Engine 302 production block selection
  • FastDriver
  • May 19, 2024
  • 2 3
8K
Fox 5.0 Mustang Tech Jul 1, 2025
FastDriver
Cold start problems - bouncing idle...
  • Andrews24
  • Apr 18, 2021
3K
Fox 5.0 Mustang Tech Jul 30, 2021
Mustang5L5
