How much do valve springs affect performance?
  • Thread starter Thread starter NorCal66
  • Start date Start date Feb 22, 2004
NorCal66
334
Virginia Tech, Blacksburg, VA HOME
Feb 22, 2004
  • Feb 22, 2004
Well I dropped in my cam in late August, and foolishly didn't put in new springs while I was at it. I don't rev the engine high, and it's just a street/dd, but I'm wondering if having the lower tension springs is hurting my performance, even at lower rpms. I just read on a site that "As long as good matching valve springs are used with a good quality set of lifters, there's no reason a hydraulic cam can't do well on the street or the track..."
Cam specs changed from stock to the Edelbrock RPM (specs in sig), which is quite a big difference in lift. I always thought it was no big deal unless you started to rev it up, but if it's hurting my performance/milage/safety I guess I better get it done.
Thanks!
6Stang7
1,470
Livermore, CA
Feb 22, 2004
  • Feb 22, 2004
If the springs were not made for a cam with that much lift, then change them. The only real performance I can see being lost is reduction in redline. Some springs can't handle high lift cams because of the added amount of stress placed on them. For what you have ridding on the line, I would swap the springs.
-Shaun
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 22, 2004
  • Feb 22, 2004
If you don't have the appropriate valve springs, what's the p0int in having a performance cam? Weak valve springs will cause the valves to "float" if you expect any kind of performance.
Speaking of performance, I hope you changed the timing gear set also. Anything more than about 8 degrees lash in the chain WILL effect performance.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
