How much do you think it would cost?
  • Thread starter Thread starter 90mustangfan
  • Start date Start date Dec 7, 2007
90mustangfan
93
So cal
Dec 7, 2007
  • Dec 7, 2007
To have a trickflow top-end kit prefessionally installed...I would do It but Have no time, and The fear of all the little things, adj. rockers, making sure all bolts are to proper specs, etc. What would it cost to have installed...Not at ford dealers, but just a mustang place or good mechanic shop.
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Dec 7, 2007
  • Dec 7, 2007
my guess...1,750 at the minimum. it could get expensive fast.. really alot of it depends on what shops around you charge per hour.
your best bet is to start reading up on it or find a freind who knows when he is doing more so and have him there when you do it to guide you through it.
bloopbloob
578
Alberta
Dec 7, 2007
  • Dec 7, 2007
maybe try and find a stangnetter near you? lots of these guys on here are just as good as mechanics, and also love working on these cars. maybe offer $500 or $1000 and some beers if they actually know what they're doing????? otherwise, around here, it would be over $2000, maybe $3000 for the install. (and you'd probably have to wait a month or more)
squeak93
2,342
414
164
Joplin, Missouri
Dec 7, 2007
  • Dec 7, 2007
I say save some money, find time to do it and a very knowledgeable person to lend a hand (maybe throw them some money to help, would be much much cheaper than a shop plus you get to learn and say you do your own wrenching)
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
Dec 7, 2007
  • Dec 7, 2007
Enough to make you find a way to do it yourself, put it that way!
jhonda
125
Huntersville NC
Dec 7, 2007
  • Dec 7, 2007
I got a quote to do everything from oil pump to lifters(seals, rings, bore, pistons...etc) for 825 dollors plus 650to pull and install the motor.
Plus I would add some kind of HCI so tack on another $600(thumper)to $895(patriot) heads, $300 cobra intake, $250? for a cam
so total price is between $2025, and $2320
bloopbloob
578
Alberta
Dec 7, 2007
  • Dec 7, 2007
just curious what certified mechanic shops charge in everyones area? around here its about $125/hour i think now? maybe more.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 7, 2007
  • Dec 7, 2007
I'm willing to bet it'd cost more than you'd pay for the kit. Your best bet is to call around some shops and ask what they'd charge to do headgaskets, since that's the same work they'd essentially be doing with swapping on the new H/C/I. Add probably another hundred or so to the price they give you to figure the cam swap into the price.
bloopbloob
578
Alberta
Dec 7, 2007
  • Dec 7, 2007
why not just ask for a quote for a hci???? what do you gain by asking for a gasket change, then guessing from that estimate? I know that its close to the same job, but it is not the same job. i'd rather get a quote for what i'm having done.....
BlownFiveLiter
18
108
Chicagoland
Dec 7, 2007
#10
  • Dec 7, 2007
  • #10
True, but it would give you a ballpark for essentially the same work. They'll probably throw an outrageous number out for swapping to aftermarket parts. You know how shops work, it's the same principle as "oh, you do have Explorer heads in stock? Great, I'll take them! Oh, no, they're not going on a Mustang!" as the price goes up $200 because instead of being a replacement part for an Explorer, they've now become a performance part, and the salvage yard guy just made himself some money.
91 HATCH
Banned
May 17, 2007
262
illinois
Dec 7, 2007
#11
  • Dec 7, 2007
  • #11
i sure am glad i do my own work all i pay is for the parts if i had to pay for install it would be easier to buy a modded fox to start out with
cliff88145
87
Dec 7, 2007
#12
  • Dec 7, 2007
  • #12
What part of So Cal do you live in? Im in the high desert and just did this same tickflow swap by myself (H/C/I).
bob331T76
76
so cal
Dec 8, 2007
#13
  • Dec 8, 2007
  • #13
i could help you out as well, where abouts are you from ?? im in LA
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Dec 8, 2007
#14
  • Dec 8, 2007
  • #14
At my shop we go by book hour and charge $70 per hour. I just looked up the book hour and you'd be looking at spending about $1281 just on labor.
ryan218
Dec 28, 2005
columbus ohio
Dec 8, 2007
#15
  • Dec 8, 2007
  • #15
795.0pacecar said:
A my shop we go by book hour and charge $70 per hour. I just looked up the book hour and you'd be looking at spending about $1281 just on labor.
thats what shops up here charge too...
90mustangfan
93
So cal
Dec 8, 2007
#16
  • Dec 8, 2007
  • #16
I live out in the High desert right off the 15 freeway, just past the ?kajon? pass....
PUNISHER RACING
1,124
FORD CITY, PA.
Dec 9, 2007
#17
  • Dec 9, 2007
  • #17
I charge $500.00 to a h/c/i swap ( that covers labor and gaskets ) on a customers car with their parts, If you buy from me I'll cut you a break. That will give you an example to base other shops off of. Good luck just find a good reputable speed shop they do not have to be mustang specific. "Its just nuts and bolts"
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
