here is the rundown on the motor.
1970 351cleveland
larger solid flat tappet camshaft
popup pistons (detonates on lower than 92 octane so its a higher compression)
open chamber 4bbl heads with aftermarket dual valve springs (2.19/1.7 valves)
1.7 roller rockers
edelbrock intake with 600 cfm edelbrock carb
holley aluminum valve covers
mallory unililite distributor
the inside of the motor is clean, the picture taken above was from when I changed all the gaskets on the motor when I first got it(mostly because I was curious what heads, and cam type I had
The oil pressure is a little low, and I really don't know much about the history of the motor. It is still in the car, and I am driving it still. I just have no idea how much these things are going for.
1970 351cleveland
1.7 roller rockers
). The oil pressure is a little low, and I really don't know much about the history of the motor. It is still in the car, and I am driving it still. I just have no idea how much these things are going for.
