I have a 89 LX that I am currently spraying 75HP dry thru TB. This is a ZEX kit and it automatically adjusts fuel pressure through a fuel jet and vacum. My timing is set at 12 degrees right now. I want to bump up my shot up to 100 HP but according to the tuning sheet that came with the kit it says to retard my timing 2 degrees. And that would actually be retarding it to 8 degrees seeing they use the factory specs. I have a F303 cam and the car runs like absolute dog crap at anything under 12 degrees. As a matter of fact it most of the time stalls out at 10 degrees and when it does idle the whole motor shakes and it idles at around 400-500 RPMS. So can I spray 100shot at 12 degrees advanced safely and w/out detonation or not? My kit is a ZEX 5.0 dry kit part # 82015. I am also using a ZEX traction control window switch. I have it set up to spray from 3000-5500 and to start spraying in 3rd gear and on. I have been considering programming it to start spraying in 2nd gear but even with drag radials I think I will lose traction spraying in 2nd gear ecspecially since its going to start as soon as I hit second under WOT. But I really need to know about the safety of the 100 shot at 12 degrees timing. My engine is as follows:
302 stock block with new rings seals bearings(about 3000 miles on them now. my rods and stock pistons reconditioned)
Edelbrock 5.0 performer intake manifold
75MM BBK TB
73MM C&L MAF
24# injectors
255LPH holley fuel pump
BBK fuel pressure regulator
MAC CAI
F303 cam
WC T5 tranny
Aluminum drive shaft
BBK full length headers 2 1/2 flowmaster exhaust
75MM BBK TB
73MM C&L MAF
24# injectors
MAC CAI
F303 cam
WC T5 tranny
