dude! you sound like me!
you could probably get away with a meth kit and low boost. but then you'll get hungry for more power and your options will be limited. with a 408, you can really up the ante
just keep in mind that that route ends up costing more because of the stuff you can't use anymore, like headers, lower intake, fuel rails, and oil pan just to name a few.
then there are the decisions you have to make, like do you keep the 94/95 accessories or go to fox stuff? you have more options with fox stuff and you can get march brackets for it then.
then there are the unexpected issues that crop up, like if you get a new k-member to make space for long tubes and also drop the motor to get it under the hood, then the steering shaft isn't long enough so you need a new one of those, ...
fwiw, you might wait until mine is done, because after i get my 302 block out, i'll be building a killer 331 (probably with afr 185s and a comp xe274 cam) and dynoing it for the learning experience. and if i still have the kb, i'll bolt that on too. if i really love the 331, i might yank the 410 out and put in the 331 (extremely unlikely), but i'll probably sell the 331 at cost.
