How much timing is good on a NA car and what A/F?
I'd setup the fuel table where it produces a wysiwyg for your final af ratio verified by your dataloggs.
then
Select something a bit fat like 12.25 to 1
then
Setup your spark table for 32 to 38 total and have it all in by 2500, again, verified by your dataloggs.
Lean fuel and adjust spark to what your combo likes
Worked for me :)
Grady
nope about 26* total at WOT or high load
They do have up to 50-55* in mid load and with the EGR kicking....#1 why IMHO keep the egr or dump it (no real need to though as its off in WOT anyway) and turn it off in the eec. or its det. city.
I would do exactly what Grady said, every combo is a little different.
Grady and I have similar combo's but they responded in different ways. My hp didn't change with an A/F of 12.5-13.5, but my hp did change with timing changes.
Grady experienced the opposite, maybe its the difference in the AFR vs. TW heads?
Keven
I had forgotten I laid out the fuel table thing on my site but while looking for some stuff for Chad ...... I saw it:shrug:
Look right after WOT Tuning on the tuning page :D
In a nutshell, for a na combo using j4j1 ...................
1) You kill the high speed fuel adder
2) You take the table and make all high load values the same
3 )You tweec only the OL part of the maf curve until wb and table values match
This method will allow you to simply dictate what ratio you desire by the value you plug in the high load row of the table :banana:
WB no longer needed for wot after this method ;)
Grady
