I'm having alot of trouble getting my bbk springs to fit in my car, I'm attempting the mfe meathod but its not working out for me i cant get the wholes to line up to bolt the a arms back up. how much would it cost ( ballpark figure) to have my springs compressed at a shop and banded? and all i would have to do after that is come home bolt up the arms and clip the bands right?
Get a bunch of those hose clamps, compress your springs with the compressor, and clamp a bunch of them around each coil. Careful though cause some of them will want to break while you unload the compressor, so do it slowly. I only spent like $15 for 100 clamps or if you got like 10-15 laying around. I tried zip ties and they popped like zitts. This will work and it's cheap!
Why did you unbolt the control arm from the k member???? You unbolt the strut from the spindle and pull the stocker out that way, and the new, shorter lowering spring will slide right in! THen jack up the control arm and bolt up the strut... The only reason I've ever had to unbolt the control arms from the k-member is because I was installing drag springs (higher spring rate, and about two inches taller) They wouldn't fit in the strut/spindle way... I had to unbolt the control arm from the k-member, stick the spring back in, and jack the control arm back up to install the bolts... it was a pain, but not too bad. Good luck.
