How much trouble to rebuild a t5?
  • Thread starter Thread starter 90_Red_LX
  • Start date Start date Dec 9, 2007
90_Red_LX
668
Asheboro, NC
Dec 9, 2007
  • Dec 9, 2007
Debating on whether to upgrade my tranny or just tear it apart and fix the synchros or put a stronger gear set in it. I'm pretty mechanically inclined, dad owns a professional shop, then I go to school for machining should I need something from that area. Would I still be batting out of my league? If the thing came apart a year from now I wouldn't really care I'll be working full time by then, but with the 2nd gear synchro well on her way out the door, and 3rd starting to act up a little I believe her days are numbered.
trbkrb
1,976
Houston, TX
Dec 9, 2007
  • Dec 9, 2007
Many guys have done it . Here is an article a friend put together on the rebuild. There is also a PDF T5 rebuild manual available on the web. I have a copy, I'll just have to find it if you don't.
http://pomoforacing.com/tech/T5Rebuild2002.pdf
rd
3,316
63
109
Ocean Springs MS
Dec 9, 2007
  • Dec 9, 2007
Its not really that hard. I did our Jeep CJ7's T5 several years ago using a Haynes manual and a MM&FF article.
With the backup you have, it should be easy.
Mustang5L5
Mod Dude
Feb 18, 2001
43,249
17,934
224
Massachusetts
Dec 9, 2007
  • Dec 9, 2007
I've done mine in my living room. One of the easiest manual trans to rebuild and a great way to cut your teeth on one is to just download the manual and tear into it.
90_Red_LX
668
Asheboro, NC
Dec 9, 2007
  • Dec 9, 2007
I may get to it then. I'm fixing to pretty much retire the car for nice weekends only since once it gets cold, the salts gonna hit the roads and the jeeps gonna get full time duty. Going to the bottle around new years also, so somethings gonna give, and the tranny is the weak link in my drivetrain.
F
Flying Dutchman
48
Nothern central Massachusetts
Dec 10, 2007
  • Dec 10, 2007
They are easy, i found the info on 5speeds.com very helpful and parts from the gear box saved me alot of time and money.
stykthyn
5,232
2,652
223
gainesville
Dec 10, 2007
  • Dec 10, 2007
where do you get rebuild kits? how much do they normally cost vs having it rebuilt?
Mustang5L5
Mod Dude
Feb 18, 2001
43,249
17,934
224
Massachusetts
Dec 10, 2007
  • Dec 10, 2007
Rebuild kits are normally $100-200 depending on how complete a kit. Some just have wearable items while others have bearings as well.
They DO NOT replace hard parts like gears however, so if you have a grinding 2nd gear, a rebuild kit may be all you need but you migth find the gear and synchro ring are bad as well and those are $35-80 each right there
trbkrb
1,976
Houston, TX
Dec 10, 2007
  • Dec 10, 2007
Here is that T5 manual:
http://statefilingsoftware.com/pictures/t5manual.zip
90_Red_LX
668
Asheboro, NC
Dec 10, 2007
#10
  • Dec 10, 2007
  • #10
I guess the only way to see whats wrong is tear her apart and see what she needs. I'll put her on the racks one weekend after christmas and see whats up.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 10, 2007
#11
  • Dec 10, 2007
  • #11
See http://www.ttcautomotive.com/English/onlineorder/product.asp to download a FREE service manual for T5 or Tremec 3550/TKO
You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
See http://www.hanlonmotorsports.com/ or http://www.ddperformance.com for parts
A T5 rebuild kit with syncros, bearings and other small parts costs about $160. It does not include any gears or shafts.
http://www.hanlonmotorsports.com/ also has a video on how to rebuild your T5 or Tremec. It costs about $20, and is worth every penny of it.
I did a Tremec 3550 rebuild, and it wasn't that difficult. The video was an immense help, and I would recommend viewing it. At $20, it will give you an opportunity to look and decide for yourself if you think that it is something you want to try to do.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Dec 10, 2007
#12
  • Dec 10, 2007
  • #12
a lot of the time its not just the friction clutches wearing themselves, its the "dog teeth" on the slider rings wear and that causes the grinding noise when you try to shift quickly or at high RPM. you may have to replace your 1-2 slider along with new clutches/bearings/etc. i believe the sliders cost 80$ ... but i cant remember for sure. tear it open and inspect everything to know for sure.
AND REMEMBER TO BREAK IT IN AFTER YOU REBUILD IT!!! my first trans rebuild ended in disaster because i went to thrashing it right away.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Dec 11, 2007
#13
  • Dec 11, 2007
  • #13
I highly recommend the Hanlon video - it'll be one of the best $20 bills you ever spend.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Dec 11, 2007
#14
  • Dec 11, 2007
  • #14
I completely rebuilt one including new gears. I went with the upgraded alloy gears and the T5-Z ratio. I got my parts from Astro Performance and just used the T5 rebuild manual. It was actually quite simple just took some time. No real special tools required except for a shop press. As far as the slider rings, I had some machine work on mine to make them easier to move.
90_Red_LX
668
Asheboro, NC
Dec 11, 2007
#15
  • Dec 11, 2007
  • #15
How much did that run you? Will the tranny hold a lot more power? As far as ratios if anything taller gears would be a lot better for the car or put a less aggressive rear end gear in it since 4th gear is all but done in the 1/4 now. If I go to spray it'll be in 5th quick.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Dec 11, 2007
#16
  • Dec 11, 2007
  • #16
I am going to look into that and it sounds interesting.
Since we are on the topic, here is another PDF T-5 Rebuild online:
http://www.ttcautomotive.com/English/media/pdfs_autogen/T-5_Service_Manual.pdf
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
R
2005 V6 manual shift issue
  • Rrf
  • Aug 28, 2023
  • 2005 - 2009 Specific Tech
2K
2005 - 2009 Specific Tech Aug 29, 2023
Dino Dino Bambino
T5 questions, replace vs rebuild
  • AnthonyA1234
  • Nov 1, 2022
  • 2 3
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 21, 2022
Mustang5L5
