How often do you clean the K&N air filter?
Ok ok.....busted. Its not that it actually performs better dirty...but dirt doesn't seem to bother KN's as much as your standard paper filters. I'd really say cleaning depends on your conditions.
Here's a little more from KN about their products
The dirt particles collected on the surface of a K&N element have little effect on air flow during much of its service life because there are no small holes to clog. Particles are stopped by layers of crisscrossed cotton fibers and held in suspension by the oil. As the filter begins to collect debris, an additional form of filter action begins to take place because air must first pass through the dirt particles trapped on the surface. That means a K&N air filter continues to exhibit high air flow throughout the life of the filter while it is accumulating dirt. At the same time, the air flow for an average paper air filter can decrease dramatically as the paper element gets dirty. So as dirt accumulates, the performance advantages of a K&N air filter can increase! Tests performed by an independent laboratory commonly known as the Frazier Permeability Test have shown that the Medium used in K&N air filters flows more than 300% more air than paper air filter medium when compared on a square inch per square inch basis. A Square inch comparison is not directly proportional to the increase you can expect from installing a K&N air filter in replacement of a paper air filter due to the effect of such things as filter size, number and depth of pleats. However, you can be assured a K&N air filter will provide dramatically more air flow which can enhance engine performance.
once a year or as mentioned before, whenever i get bored
a problem i had with the k&n cleaner kit is that i'd run out of the cleaner and still have plenty of oil left. simple green works well and solved that problem:nice:
+1, once a year ...
Good info on the simple green also, I'll keep that in mind. I always run out of the cleaner also but have bottles of the oil. Weird...
Just cleaned mine last night. It only had about 8,000 miles on it, but it was very dirty. Cleaned and oiled it and now the car feels strong again. They say that the more dirt on the filter the better it "works", or filters. However your car may run a little sluggish because of this, because I could definately tell the difference once I cleaned it. It was a significant SOTP improvement!
I'm not too good about cleaning mine either, I should probably pay more attention to it since I now have a blower. The other day I ran a 1200 mile trip to my parent's house in the Smokie mountains and back to Fla, the car was running rough so I looked at the K&N, It had a freakin' Honda stuck in it.:shrug:
