how to adjust steeda quadrant?
Black Stang 97
the guy on top of me is funny
Nov 11, 2004
483
Los Angeles, CA
well i finally finished the installation of the steeda 3 peice......but im having a hard time getting the clutch height and clutch engagement correct....i dont know if this is possible...but i want my clutch pedal around the same height as the brake and want to engage sumwhere around the begining....can someone help me out?? thankz
The steeda adjuster kit does not set the height of the peddle unless you get the bump stop! which will set it to around brake height or possible a bit lower.
I believe it's miss advertising stating that it adjust your peddle,,, it only does if you buy the bump stop!!!!
