How to bypass stock amplifier?
  • Thread starter Thread starter RsStanG1987
  • Start date Start date Jul 26, 2005
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Jul 26, 2005
  • Jul 26, 2005
Does anyone know how to do it??
strokedandblown
Banned
May 3, 2005
555
USA
Jul 26, 2005
  • Jul 26, 2005
what are you trying to do? if you have a new HU just run new wires through the car
RsStanG1987
569
9
79
Dupont PA
Jul 26, 2005
  • Jul 26, 2005
Im trying to get the speakers to work with out running all new wires...
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jul 26, 2005
  • Jul 26, 2005
Unplug/remove the amp and short jumper harness. Use the wires that plugged into the amp to plug into your new HU -- the connectors are the same. The amp should be located directly behind the HU in an 87.
strokedandblown
Banned
May 3, 2005
555
USA
Jul 26, 2005
  • Jul 26, 2005
go to the amp, i think its under the pass seat. You should be able to see the wires coming out of the amp *(a cluster of 8) check the color and then verify w/each speaker in the doors and back go one by one so you dont mix up polarity. You are going to have to run short runs to the amp location from the HU so you can splice in to the correct wires . Good luck
RsStanG1987
569
9
79
Dupont PA
Jul 26, 2005
  • Jul 26, 2005
What????? The amp is right behind the radio.
Scorcher2005
883
South Carolina
Jul 26, 2005
  • Jul 26, 2005
ive heard in some cars its behind the glove box
5.0 con-vert
No soup for you, Joe Rogan!!!
Jun 7, 2005
244
Boca Raton, FL
Jul 27, 2005
  • Jul 27, 2005
allright...
The amp in an 87 is behind the head unit! Its the little metal box that doesn't look like an amp!
If you don't want to do any crazy wiring, or if you plan on keeping the head unit to re-install before you sell, just buy one of the harnesses from Crutchfield for like 10 bucks and call it a day. I used one of these and it worked like a charm
bmo37
2,368
New Jersey
Jul 27, 2005
  • Jul 27, 2005
depending on the year of the car the amp can be behind the head unit, or under the passenger seat (my was 92, and 93's both were)
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jul 27, 2005
#10
  • Jul 27, 2005
  • #10
5.0 con-vert said:
allright...buy one of the harnesses from Crutchfield for like 10 bucks and call it a day. I used one of these and it worked like a charm
Click on the link below... It's for an 89, but you can easily change years (harness is probably the same.) This is the easiest way to bypass your amp.
Crutchfield Wire Harness
R
raginbul469
160
michigan
Jul 28, 2005
#11
  • Jul 28, 2005
  • #11
you can go to a best buy and buy the BBFD02B
this is the harness you need.
dont use the 2 gray plugs that plugged into the radio.
use the black and gray rectangular bypass plugs that are found in the back of teh radio cavity.
your welcome
RsStanG1987
569
9
79
Dupont PA
Jul 29, 2005
#12
  • Jul 29, 2005
  • #12
Yeah the 2 plugs that came out of the stock radio were black and grey.
Daniel50
716
Discovery Bay, CA
Jul 29, 2005
#13
  • Jul 29, 2005
  • #13
any benefit on keeping the stock amp?
5.0 con-vert
Jun 7, 2005
244
Boca Raton, FL
Jul 29, 2005
#14
  • Jul 29, 2005
  • #14
Not if you plan on running a new head unit. The newer units by themselves push out well more than the 35 total watts that the stock amp does. most of todays units are about 35x4 or more. Basically the stock amp is...NO GOOD!
bmo37
2,368
New Jersey
Jul 29, 2005
#15
  • Jul 29, 2005
  • #15
yep i did the same thing I think way back when i swapped the head unit out i just bypassed the stock amp completely just cause the head unit itself was 300w
5.0 con-vert
Jun 7, 2005
244
Boca Raton, FL
Jul 29, 2005
#16
  • Jul 29, 2005
  • #16
but if you remove it you take out about a pound of weight and increase HP by about 20... WTF!
1SAVG93
48
Vacaville (Bay Area), Ca
Mar 13, 2011
#17
  • Mar 13, 2011
  • #17
does anyone know where the stock amp is in a 91 mustang gt??? so i can by pass it or take it out because its not behind the head unit... thanks
Mustang5L5
Mod Dude
Feb 18, 2001
43,375
18,122
224
Massachusetts
Mar 14, 2011
#18
  • Mar 14, 2011
  • #18
Its behind the radio. If it's not there, then your car had the basic 4-speaker system without door speakers.
If you have an amp there you would have 6 speakers
Engine What’s that?
  • PonyGTrider
  • Aug 24, 2026
Fox 5.0 Mustang Tech Aug 25, 2026
PonyGTrider
R
Interior and Upholstery How to remove seatbelt torx screw
  • Riley Barth
  • Jul 6, 2026
Fox 5.0 Mustang Tech Jul 13, 2026
Forced Induction Bypass valve reference
  • JD1964
  • Jun 1, 2025
Fox 5.0 Mustang Tech Jun 1, 2025
JD1964
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
