  • 1994 - 1995 Specific Tech
how to change shiftkit
  • Thread starter Thread starter Mustangless
  • Start date Start date Nov 14, 2005
Mustangless
903
home
Nov 14, 2005
  • Nov 14, 2005
When I bought my car the transmission had just been rebuilt and the recipet and the owner said a shiftkit was installed. I am going to be getting a converter installed sometime this week or next. How do you change the firmness of this? Also is it obvious that it has a shiftkit? Or is it really hard to change? Its going to be getting flushed and a new filter also.
Dan95-5.0
1,110
Manitoba, Canada
Nov 14, 2005
  • Nov 14, 2005
it depends on what shiftkit was added.
a b&m just replaces a seperator plate with pre drilled holes.
on my transgo, you choose the which size you want the holes
because i was getting a highstall added at the same time i only put one spacer in instead of 2 but i drilled to the largest size.
it shifts pretty good and really hard when at WOT. even chirps 2nd and 3rd.
bjl95mustang
1,495
Austin,TX
Nov 15, 2005
  • Nov 15, 2005
www.tccoa.com
go to tranny then tech.
There are diagrams on there on what to drill out to make it shift firmer.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
