In answer to your first question, pull the snap rings off the airbox and loosen the clamps that hold it on the MAF. Unplug the MAF sensor so the wire does not break if you drop the thing. After you pull the top off the airbox, pull the filter out and see if the silencer is there. The smog pump is located under the alternator. If it is bypassed, the belt will not be hooked up to the pulley.
In answer to your second question, underdrive pullies should be fine. A lot of people do not recommend them though because they slow down the accessories. I don't have them because I know of people having headaches when they put them on.
